Valve stem seals?
Old Feb 16, 2015 | 10:51 PM
Silver_Bullet_Z28's Avatar
Default Valve stem seals?
Can anyone shed some light on the difference in valve seal types between different year model f bodies? I see 2 kinds of valve seals, 1 regular and 1 that looks like a top hat. I'm reading things saying LS1s up to 2001 use regular and 2001+ use top hat style. My car is a 2000 and has 853 heads currently but I'm swapping them out for some Advanced Induction CNCd 241 heads I have laying around. Does this mean I need top hat style seals? And should I get Viton or GM OEM as far as brands of seal? Thanks guys
Old Mar 28, 2015 | 04:28 AM
squalor's Avatar
I want to know too.
Top Hat style
I have bare 243s and want to use beehive springs, is this what I need or do I need OEM spring locators ?
Silver_Bullet_Z28 , what did you find out since you posted this ?
Old Mar 28, 2015 | 09:33 AM
vettenuts's Avatar
The older seals use a separate seal and spring seat. The later ones us a combined seal and spring seat and look like the top hat you describe. The later seals are assured of staying in place because the valve spring will hold it down.
You can use either with beehive springs on your 241/243 heads, however if you use the older style you must install spring seats. If you are going with double springs, than you need the older style since the double springs will have different valve seats.
Hope that makes sense, or is it clear as mud?
Old Mar 28, 2015 | 05:32 PM
squalor's Avatar
Thanx vettenuts, it makes perfect sense. So the Black intake/Tan exhaust refers to the old style that can be used with the separate beehive spring locators or dual spring locators. I have a WTB thread going to buy some OEM retainers and locks but now I know I do not need the spring locators.
One other thing sir. If I shim to installed height after a valve job, do the shims go under the hat ?
Old Mar 29, 2015 | 06:13 AM
vettenuts's Avatar
No, shims go on top. If you shim under the "hat" it will lift the seal up off of the guide and allow oil to get by. Just to be sure we are on the same page:
1. Beehive springs - New style seal with built in seat (all one piece top hat)
2. Beehive springs - Old style seal with separate seat
3. Dual springs - Old style seal with dual seat made for spring being used
Old May 20, 2015 | 09:06 PM
voda1's Avatar
Anyone have the GM part number for "all one piece top hat" seal?
Old May 21, 2015 | 11:53 AM
gagliano7's Avatar
http://www.briantooleyracing.com/ls-...hat-style.html
http://www.lingenfelter.com/mm5/merc...E#.VV4N6cLbJ2s Exhaust seals
http://www.lingenfelter.com/mm5/merc...E#.VV4OGsLbJ2s Intake seals
Old May 21, 2015 | 02:13 PM
squalor's Avatar
I think the GM top hats are 12482063
I ended up going with Summit's house brand SME-143008
Old Feb 4, 2017 | 01:05 AM
rkulp89's Avatar
I know this is old but can anyone confirm that the SME-143008 valve seals will fit 862 heads on a 4.8 LR4 w/ tophat seal design?
Old Jul 18, 2022 | 12:08 PM
RobPH's Avatar
Default Need advice on which design to buy 2001 5.3 silverado
Which design would be better 1st or 2nd valve seal? Not sure what is in there now probably 1st? Need a little direction I know this is an old thread but need some good advice thanks. I have a 2001 Silverado 5.3 vortec (LM7) Vin code T.
Old Jul 19, 2022 | 11:24 PM
Metalchipper's Avatar
Wink Floating valve seals
Hello, if you decide to go with non- top hat design......
Make sure you use Comp 519-16 seals, I got mine from Summit. If you use the kind with the viton inside the seal .... they might become floating seals!!!
Out of 16 only 4 where still on the guides after 1 year!
Two floaters
Oil river in the exhaust
the one on the left is the type that floats The [middle] good one has a metal to guide surface...
Old Jul 27, 2022 | 01:11 PM
ChrisSilver01Z06's Avatar
Two floaters
Ah what a pain, but that's a great tech tip. Thank you.
Old Jul 28, 2022 | 12:32 PM
Talking Up date
I think the reason why the seals floated up is...... the valve guides were wore out. Well, the machine shop reamed the new ones out too much, the second machine shop said that is why the valve seals floated. I thought they were loose when I picked the heads up after the earlier valve job, I should of had them redo it. that was about 10,000 miles ago and I put on the metal seals then. Then later I took the heads off because of noisy lifters and replaced the seals with the viton inside the base of the seals.
I do not mind when I goof something up, I learn from that. It pains me when I pay some one else to mess things up!
Old Aug 2, 2022 | 09:46 PM
RobPH's Avatar
So which gm part would be best to get? Or should I get the comp ones?
Old Aug 3, 2022 | 08:05 AM
Talking
What are you doing to the valves? Could use some more information. This thread has some good information ------- before I messed it up!
Stock valve train, the top hats. You do not need to buy them from GM.
Bigger sized springs that do not fit the top hat type, or duel springs, then the smaller ones.
Hope that helps.....
