May have been burned on this 4.8
Once water has been mixed in with the oil, I would atleast inspect rod and main bearings, if wear there is minimal then everything else 'should' be okay. Not all leaking head gaskets put water in the oil so I would definately get the heads checked out thoroughly for cracks. When you take the heads off, look around for a spot where they might have been leaking, i.e. broken gasket or something. If water is getting into a cylinder that piston and chamber should be cleaner than the rest.
