Double checking before I buy new cam.
ported ls6 oil pump (tsp)
ls2 timing chain
Longer ARP cam bolt
228r cam package from texas speed
The Kit comes with
-228r camshaft 10 LSA
-Texas Speed Hardened Chromoly Pushrods (7.400 length)
-Single Beehive valve springs Rated to .625" Lift. (I can buy dual instead if I need to)
http://www.texas-speed.com/p-1157-te...ve-spring.aspx
I know I will also need a dyno tune but is that it?
What about titanium retainers? yes? no?
I'm open to any input. Thanks guys
2000 ls1 trans am
Air & egr delete, long tubes and exhaust. 105,000 miles,manual transmission.
I would go bigger but I have never had a cammed LS.
I am not sure how big I can go without causing problems. I would like a "simple swap"
It's my daily but I do have something else to drive.
And I plan on just a cam. Something that's nice and fun.
Its a daily (not really crappy mpg, its in the tune but you get the point) so I don't want something to unreliable and I don' want a small baby cam.
I want it to fit without having to flycut anything.
I plan on just going cam only for a long time.
and oh okay I'll be going with steel retainers then! thanks man
http://store.cammotion.com/the-titan4
http://store.cammotion.com/double-sp...teel-retainers
http://store.cammotion.com/pushrods-516-x-7425-120-wall
Wanting more feedback because this sounds like what I'm about to get. Thanks(:!
ls2 timing chain
Longer ARP cam bolt
The Kit comes with
2000 ls1 trans am
If you wanted a bit more cam something like a Speed Inc SI5 231/237 or TSP torquer 2 232/234 would be a good choices as well.
http://www.tickperformance.com/tick-...1-ls6-engines/
Everyone has their own way of looking at cams and specing them and pissing on them. I have a tough ski. I was merely clarifying and giving an explanation.
And there are more than three lobes for a 227-228 @ .050"... there are the HUC, LSL, XE, XE-R, XFI, LXL, etc. More lobes from Cam Motion, throw in Lunati lobes, EPS or Ed Curtis or Damian or Futral custom lobes and yeah, you get the point.
Something around 228/232 is a very good cam in the LS1.
