Thinking of tackling a cam install myself
I have a 00 ws6 has about 100k miles. So far i have done
Slp Lid
Ls6 intake
Hooker headers
Magnaflo and Y pipe
4:10 gears
I would like to add a cam in the next month or so. Just from reading around a ms3 might be the way i want to go. Any pro's or con's to this decision?
I have never done a cam install in a TA, surely there is a good write up i can stumble across.
The car is not a DD i drive it about a day or two a week usually.
Search for my thread "cam install from hell" to read how not to do it, or if you just want a few laughs.
As to which cam - anything in the 224-230 range on a 110-112 intake center line will give you a good power upgrade over stock and still drive pretty well. You don't indicate manual or automatic transmission. If auto, you'll need to look at a higher stall converter
If you did the headers yourself, you can do the cam swap. Ls1howto has a great write up with tons of pictures. Instead of the JRP tools, you can use 24" long 5/16 dowels to hold the lifters
here is a thread that gives you a few things that will be needed for the install. I have never done one myself but I can tell you it will take a while, probably a weekend project.
*** Cam Guide ***
Post #5 has a link for probably one of the best and widely reference write ups for installing a cam and valvetrain into an LS F-Body.
