About ls connacting rod
Old Mar 12, 2015 | 12:07 PM
sahwan's Avatar
Default About ls connacting rod
Hi
I have mahle piston for my 5.3 engine I want to use my stock connacting rod but my stock connacting rod Fit press pin and the mahle had floating pin is what must I do ??
Old Mar 12, 2015 | 12:13 PM
redtan's Avatar
Get a floating pin connecting rod?
Why you would want to reuse the stock ones is beyond me. Even a basic OEM Gen IV rod is cheap enough to swap in.
Old Mar 12, 2015 | 12:31 PM
sahwan's Avatar
I have floating pin with my new Pistons , I want to change my old Pistons with new mahle Pistons
Old Mar 12, 2015 | 12:57 PM
KCS's Avatar
KCS
Moderator
Originally Posted by sahwan
Hi
I have mahle piston for my 5.3 engine I want to use my stock connacting rod but my stock connacting rod Fit press pin and the mahle floating pin is locked what must I do ??
If your rods are press fit and the pistons are floating pin, then they'll work together just fine. Take them to a machine shop to assemble.
Old Mar 12, 2015 | 02:24 PM
sahwan's Avatar
I take is to machine shop he doesn't know what he will do he asked my what do you want me to do
Old Mar 12, 2015 | 04:19 PM
KCS's Avatar
KCS
Moderator
Old Mar 12, 2015 | 09:03 PM
sahwan's Avatar
Ok but the new piston had floating pin it's ok if I press it ?? I will not have any problem in future??
Old Mar 12, 2015 | 09:33 PM
KCS's Avatar
KCS
Moderator
Nope, it'll be fine.
Old Mar 13, 2015 | 03:46 AM
racer8088's Avatar
Depends on what size the pins are.
Old Mar 14, 2015 | 08:09 AM
A.R. Shale Targa's Avatar
Thought I remembered reading that pressed are .943" and float are .944"
If true, a competent machine shop could still hone the rod small ends to get the correct interference fit.
A few other options are as someone suggested, get a factory full floating rod
or just hone the small ends enough to float them metal on metal. I've run engines like that on the street plenty of times. We used to just drill a small oiling hole into the end of the rod (top inward toward the pin hole) and with .0008" clearance they would often look just fine on repeated teardowns.
Old Mar 14, 2015 | 09:44 AM
96capricemgr's Avatar
I don't understand why you would put in aftermarket pistons with stock rods.
Ask questions FIRST before committing to poor choices.
What will it cost to recondition stock rods and hone them for the different pin size? Then you still have stock rods.........
Old Mar 14, 2015 | 07:25 PM
sahwan's Avatar
Because I have the Pistons for free I don't want waste more money I will use it as stock piston
Old Mar 14, 2015 | 07:29 PM
sahwan's Avatar
Thanks gays I asked mahle thay say
You can use it as Press-Fit or Floating
Wrist Pin Size: .945" same the stock size
