New Top End Build
Old Mar 12, 2015 | 01:13 PM
LS1Birdy's Avatar
Default New Top End Build
I'm starting to put together a list of supporting parts that I may need while I wait for the cylinder heads to arrive, and I'd like to hear some input on this build.
I've ordered some of Tony Mamo's new 220s with a custom cam grind. YT Ultra Lite rollers, and whatever size pushrods. As for lifters, Im on the fence about the LS7's if they would work fine, or if I need to go for aftermarket ones.
For induction I'm looking at getting the Fast 102/102 combo, but I was reading that the 92 works better because of the velocity, hard to say, since I read it on the internet . I'd like to keep a MAF on it and not run SD, so I'm leaning towards the 85mm.
The injectors are stock 28lbs and I have a good feeling that this build will push them beyond their limits. Maybe go with 36 or 42lbs, and hopefully the fuel pump is up for the task.
It currently has Mac Mid-length headers with high flow cats, to a cut-out. I'm going to keep the exhaust for now, but will look into better manifolds in the future.
Feel free to tell me your thoughts and opinions, I am all ears. Thanks!
Old Mar 12, 2015 | 02:03 PM
redtan's Avatar
I would at least get the $200 Morel 5315s, no sense in going with such a nice build then skimping out a few bucks on a vital part of the engine. Not that LS7s aren't decent units, but for 70 bux more you can get much better ones. Although if I were doing such a high dollar build I would most likely opt for some Morel or Johnson linkbars.
Again, for such a top of the line build I wouldn't just toss a shitty 85mm MAF in there. If you must have one, get the LS3 card style one and toss it into a nice 4" aluminum housing.
Definitely going to need injectors. 36lb should be ok, but to be safe get some 42s.
Old Mar 12, 2015 | 02:49 PM
Tuskyz28's Avatar
Definitely get the morel 5315 lifter if not nothing better. I hate to see guys put a great combo together the a LS7 lifter eat a lobe off the cam.....
Also talk to Tony about the intake and injectors.... he'll guide you on the right track.
Old Mar 12, 2015 | 03:05 PM
SoFla01SSLookinstok's Avatar
Nice choice on heads!
Go for the 5315s. I'm glad I did. Especially with a roller rocker.
Old Mar 14, 2015 | 09:17 PM
LS1Birdy's Avatar
Thanks for the advice. I've been out of the LS world for awhile so i wasn't quite sure on the parts these days.
Old Mar 14, 2015 | 11:48 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Mike,
Just let me steer you into the right parts....if you truly want to get the most from these heads (and I assume you do), let me help you with all the right supporting mods to let them really work for you. The largest part of the financial pain (and most important choice you will make concerning power output) is behind you, but getting the rest of the package correct is just as important or some of the heads potential will never be fully realized.
I may call you this week so we can get a game plan together. Even if it takes longer to finally get the install going, having the right parts and ending up with a really efficient well working combination when the smoke clears is well worth it and its just smart to approach it in that fashion. Any heads cam project (even "budget" stuff) goes over budget all the time and is a huge endeavor from the planning stage till the time you finally roll it off the dyno and your staring at the dyno sheet before your first hotly anticipated drive. The more planning and better the overall combination is the more satisfying that future day will become.
I will be in touch!
Cheers,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
