New 408, help me decide on a top end
You must had been looking at those guys running 317 heads on 408 Ci motors LOL
What is everything needed to do a ls3 top end? Intake, some sort of heads, fuel rail, but what does everyone use for a cable driven throttle body? Are the ls3 injectors good enough for a 408? Where do you get the adapters to plug them in? Are there any more sensors needed that won't adapt from the ls6 setup?
The Scammer Hammer
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ok it's sounding like the ls3 top swap is right for me especially given my ls6 intake restriction. Would I need rockers as well? I read something about the ls3 rockers being different.
Thanks for everyone's help and input, it is much appreciated!
Yes, the intake rockers are off set. so your looking at a set of intake rockers, do the trunion upgrade on all. Rocker stands and if your using your ls1 valve covers you will need to grind away aliitle on the inside ( no big deal ) or find some used ls3 valve covers. If you are getting the hollow intake valves ( 821 ) i believe, then your going to have 2 different valve heights.Two choices are to get 2 different push rod lengths ( i did ) or get the valve tip ground down alittle, they sell shim caps for the top of the valve but i don't like that thought.
Ok so let's compare a set of heads that retails for oh over 2k to a set of stock cnc ported cathedrals. The man is trying to remain budget friendly. We can't all afford afr/tfs heads. So let's spend under a grand for square ports and make the same power......it's not rocket science genious. Read some more Internet bs and post again, I'll wait.
From my rough figures it seems I'll be saving about a grand over a cathedral setup to flow about the same, plus I'll get the benefits of the ls3 intake over the ls6 that I'd be using. I think I'm sold, now the question is heads. What about these heads?
https://www.texas-speed.com/p-1179-p...ted-heads.aspx
Is there another comparable option that doesn't break the bank?
#33
So with the intake valves being longer does that affect the spring install? Would those have to be shimmed? Those summit heads would save even more money, I'm digging it!
#39
My Prc247 and 251/259 cam made 523/487. They had nightmares tuning it from the massive intake vacuum leak and the lifters collapsing lol. Motor had a weird knock we couldn't find and a lot of valve train noise we couldn't figure out until we lifted the rockers off the valves 1/4". Hard to say what that setup would make dyno'd healthy. You could do 247s and wait for a intake. Just a thought.
