New 408, help me decide on a top end
On the other hand I could get a ls3 top end swap and possibly save some money. I know the ls3 intake is damn near as good as a fast 90 so that's a huge plus, but this swap is still intimidating cause I don't know all the little things it'd take to make it work.
What are the pros and cons to these options? Stick with cathedral heads or go square port? Decisions decisions...
This is a t-56 street car first and foremost that sees the track about twice a month.
LS3 heads are great on a stock 376 LS3. What makes anyone think they only flow in the upper RPM. It's a 408. I think he's got all the torque he needs.
Sell what you have and recoup some money, and pick up some LS3 heads and intake. Even get them ported if you'd like. Rehr Morrison (Darin Morgan) and Frankenstein both have good programs for those heads.
MMS 235s and 11.5:1 Comp with medium HR 235*/239* - 239*/243*
.620"/.600" LSA 114*-115* +3*-4* can make 540+RWHP with all the
Fix- ins (attention to ALL the details) call Tony,it ain't cheap but
Do it once, Do it right! Mild DD that will rip your head off! LOL
I just picked up some P&P L92 heads for $800 and a LS3 intake for $180. You can sell the LS6 for $350-400 all day. If the L92 heads only make high end power, why do the put them on trucks
Great guy that does real tests on cams, heads, intakes, etc...
He also tested a 408ci motor on the dyno using both a LS3 head vs a Out the Box AFR head. The AFR head not only made more torque but it also made more horsepower.
Let's take that LS3 head and shoot it out to one of the two aforementioned companies, or even Richard at WCCH and compare again.
OP you can't go "wrong" either way. There's a plethora of options out there. I think the real question is how deep are your pockets?
