370 build need help on picking heads
500 FWHP possible with either head. Cathedral may
Need porting. Square ports need different cam, something like
224*/232* for truck and broad torque curve.
Hot Rod magazine did a 6.0 build and installed L92 heads with a carb and headers plus a tune. They tested 3 different cams from crane. First they installed a 210/218 camshaft and the motor cleared 460 horses and over 460 ft pounds of torque. This cam was the torque monster in battle which was the smallest cam tested and being the most tame as well. Every cam they tested after that was bigger and ended up losing torque but gaining horsepower in upper rpm band.... 500 horse is achievable with a bigger cam but you won't have the low end grunt as the small cam have. Hope this helps and makes sense....
Unless you go crazy high compression, those heads and cam will make for a high RPM powerband. I imagine a mud truck needing all the lowend grunt you can get, which low end + big port heads + decently big cam don't go well together.
And cams are not expensive, and you can always sell the spinmonster to recoup the money that it would cost you to get a new cam. It's not worth it to put in a mismatched cam just cuz you can save 100 bux.
I'd get some 5.3s ported, a nice high teens low 220s cam with an truck cathedral intake and let her rip.
For a mud truck, you want low and midrange torque and an intake with long runners. I would get a NNBS truck intake, use the 799s over the 823s, and get a cam with minimal overlap that is designed to operate in the lower RPM range. I would even go so far as to say to just stick a stock 6.0 truck cam in the thing.
Most people telling you to use 799 heads are just quoting what they read on the Internet. I've seen countless cam only square port cars make more power than h/c/i cathedral cars with the exception of aftermarket castings. But would you rather spend 1k on square ports or 2500 on a good set of aftermarket cathedrals to make the same power. It's a no brainer.......
