looking for a good baby cam
Old Mar 22, 2015 | 11:38 PM
99Bluz28's Avatar
You'll probably be want a cam with a intake duration in the 222-224* (@.05" lift) range with the 3200 stall TC, and any around 0* overlap with sound noticeable, so you don't need more than a few degrees of positive overlap at most to get the sound you'd like. I'd want a IVC of right about 42 with your cam choice. Now as far as making it last stick with mild cam lobes and your valve train will last longer.
The true key to getting the right cam for you is going to be telling the sponsor who is going to eventually spec your cam what you honestly wanting from your cam choice. I do recommend going no larger than a 224/228 111lsa+1 cam, and stick with mild lobes.
Old Mar 23, 2015 | 06:10 AM
cali_bear2003's Avatar
Originally Posted by Tuskyz28
Since the thread is concerning baby cams I'll figure I'll share a great link to one..... https://ls1tech.com/forums/dynamometer-results-comparisons/1213394-baby-eps-cam-lays-down-430rwhp-415rwtq-track-results.html
I was considering this same cam, but I just do not believe the results. Many others run the very same came. But with much lower numbers. I too needed something that would pass the emissions in California. In the end, I contacted Martin for a custom grind. Sadly, it's still waiting to go in
Old Mar 23, 2015 | 10:46 AM
Sales@Tick's Avatar
Originally Posted by squalor
I don't know how to match a cam with a stall speed but I think this cam could be strong at 6400 rpm. It has only 6 degrees of overlap so it should be very streetable. It opens the intake valve at 4 degrees before TDC so it should have a good amount of lift by the time the piston starts sucking on the intake port. The exhaust closes 2 degrees after TDC so it should carry RPM while keeping reversion in check. The intake valve closes at 44 degrees so it gets a bit more fill than the 42* that a LS6 intake likes to have. It has good dynamic compression and good piston to valve clearance. The exhaust opens at 46 degrees so it squeezes more out of the power stroke but it's not enough to clear the chamber at high rpm. I suspect the intake charge would suffer contamination from exhaust gasses around 6600 to 6800 rpm. I think the power would drop fast after that and it would be a bad choice for nitrous.
Still, irocurpony8489 has a nice exhaust setup so this cam would be close to what he is looking for. It would sound "noticable" too.
What lift would be good for it ?
Very good description of valve events!
Old Mar 23, 2015 | 11:07 AM
thunderstruck507's Avatar
Kip at Cam Motion is a firm believer in not over camming an engine, for what you're trying to do getting you something will be right up his alley. For instance he had my try out his "drop in" truck cam which is a tiny 205/210 cam meant to work with otherwise stock engine/trans/gears. But it still picked up 40rwhp/20rwtq with a low RPM peak (my shifts are set to 6000rpm) and a noticeable gain of throttle response/power from idle to redline.
In the past I've also used Geoff at EPS and you certainly can't go wrong there as well. Back when EPS was first becoming well known there were several accounts of smaller EPS cams running as well as larger grinds on older lobes while still being gentle on the valvetrain.
Old Mar 23, 2015 | 11:40 AM
MrSlinger85's Avatar
Spend the extra $25-50 and get a custom grind. I'd go with Pat G., Flowtech, or someone else similar.
Old Mar 23, 2015 | 12:02 PM
hiltsy855's Avatar
Originally Posted by redbird555
......This is true tune can have an effect but laregly its in the overlap. The more you have the more power you make and the choppier it gets however anything over 4 degrees you start to have trade offs, and anythign over 8 is debatable to be a DD.
My official recommendation is something like a 226/230 113+2 on eps lobes. With 2 degrees of overlap it will drive pleasent but you'll know somethings there. The next steup up from that would be to grind it on a 112 lsa giving 4 degrees overlap. Or 230/234 on a 113+3 which gives 6 degrees. All those cams will make peak power around 6200 so a 6500 or a tad higher rpm shift point is pretty optimal.
I like this one....
Old Mar 23, 2015 | 03:32 PM
99Bluz28's Avatar
Yeah, I think some people focus too much on dyno numbers, which is misleading since there's too many variables, to include the dyno itself which affect hp/tq number you get from one dyno to the next. If you acknowledge that a dyno is only a tuning tool, and that the hp/tq numbers you get are only valid on that dyno, and under the exact condition present that day, then you won't focus on then as much, and be disappointed. A good example would be a car that makes 380hp on one dyno and then 400 on another dyno across town all on the same tune, about 2 hour apart. Imo, I found that if you ask the tuner how their dyno compares to dynos at other shops in the area, you'll often get a better idea of how you would dyno at some other local shops.
Old Mar 23, 2015 | 03:41 PM
squalor's Avatar
Thank you Martin ! That means a lot coming from you !
228/228 111+1 .620"/.612" is what I'm thinking about running in my LS6/m6 RX7 . I was curious what you thought about the numbers but since I would have Kip cut it I thought it would be bad form to ask your opinion.
Now that I think about it, it would be a bad choice for irocurpony8489 . I hope he gives you a call.
Old Mar 23, 2015 | 05:34 PM
irocurpony8489's Avatar
I forgot to mention i would like to keep my ls1 intake. I tried a ls6 intake in the past got one off ebay got broke in the shipping process was a pain in the *** sending it back and getting my money back. So unless i can get one local no ls6 intake for me. Also i could care less about dyno numbers looking for quarter mile times. Car runs 12.20's as it sits now would like a cam that would put me in the 11's no matter what the weather conditions are.
Old Mar 23, 2015 | 05:57 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
What's the point of camming the motor if you're choking the life out of it? You need at least an LS6 intake.
Whoever packaged it and allowed it to get broken is a plain fool. I've shipped probably 6 intakes and never had a single problem.
Old Mar 23, 2015 | 06:20 PM
Sales@Tick's Avatar
We are also Cam Motion dealers as well, don't forget.
Old Mar 23, 2015 | 06:29 PM
  #32
I didn't want to call any sponsors until i had the money, but what do your recommend martin?
Old Mar 23, 2015 | 07:24 PM
  #33
mac62989's Avatar
If I was going small I would give the Cam Motion Street Slayer a try
Old Mar 23, 2015 | 08:31 PM
  #34
MuhThugga's Avatar
How's the fuel economy on that cam?
I've been thinking about a cam for my truck, and I don't want my mileage to plummet.
Old Mar 24, 2015 | 08:43 AM
  #35
On my usual long trip to my parents through the mountains I stay in the same 18-19mpg average as before.
Detailed thread: https://ls1tech.com/forums/dynamomet...hp-22rwtq.html
Old Mar 24, 2015 | 10:02 AM
  #36
MuhThugga's Avatar
Not bad. I've been going back and forth on doing a cam like this versus putting a stock LS2 cam I have laying around. Mostly, the debate is "free vs $450." lol
Old Mar 24, 2015 | 10:36 AM
  #37
Difference is soggier bottom end and needing to shift in the 6500-6800 range or a snappier response through the whole powerband and shift at 6000. Free is free though.
