Is my instructor wrong?
Old Mar 26, 2015 | 12:11 PM
CPower06's Avatar
I don't have compressed air, so I also used the rope method without any issues. However, I have seen it done with air before and it looks like it would be quite a bit easier.
Old Mar 26, 2015 | 12:30 PM
96capricemgr's Avatar
On an LS where plugs are easy air would be pretty easy. Something like an LT1 where plugs are a b!tch air is hard and TDC easier.
Old Mar 26, 2015 | 01:32 PM
fbody4everyone's Avatar
thanks guys, i feel like ordering my cam here in the next couple days. More confident without using compressed air. My instructor told me I woudnt be able to do the whole camswap in a day in school, maybe not even half the motor (springs) so.. I'm going with the garage style!
http://www.jegs.com/i/JEGS-Performan...ductId=2345758
and heres my choice in cam
Old Mar 26, 2015 | 01:40 PM
01ssreda4's Avatar
Originally Posted by WE TODD DID
He is trying to teach you the correct way to go about doing things. It's up to you to discover short cuts.
I do not consider air only the correct way. If it fails the valve can drop. I recommend TDC method but air and TDC method used together is THE best way to do it.
Old Mar 26, 2015 | 03:51 PM
RockinWs6's Avatar
Honestly using air can be very dangerous, If you spin that piston up to TDC then apply air the entire piston-crank assembly is going to move until that piston is at BDC. I watched as crank spun down and the socket and ratchet went spinning around with the crank! It can get hairy.
I've been doing valve seals for 40 years using the TDC method using a piece of vacuum hose to find tdc. I've NEVER had a problem. Those valves are so close to that piston at tdc its completely safe. If it does drop a little once you install the new seal it will stay where ever you put it PLUS like I mentioned before you can do 2 cylinders at a time.
I'd be much more concerned which tool to use to compress the springs....buy the very best and take your time. If you strip any of those rocker threads your gonna be screwed as fast as a rabbit gets ucked!
Old Mar 26, 2015 | 04:34 PM
99Bluz28's Avatar
The TDC method also gets my vote!
I also highly suggest getting a extendable magnet retrieval tool with a strong but small magnet. It'll be very handy with removing, and installing the locks, to prevent dropping them. Also a small hammer with interchangeable heads, like gunsmith, hobbyist, or jeweler hammer will work very good, but isn't required.
Old Mar 26, 2015 | 05:21 PM
RockinWs6's Avatar
You better vote for the TDC method or ELSE!
Old Mar 26, 2015 | 05:28 PM
RockinWs6's Avatar
One thing I have to mention if you do use a air compressor to charge the cylinders. Be sure not to leave the engine without starting when you are done. Compressed air can contain large amounts of water, if this water sits over night in the cylinders it can cause damage. Another concern in humid weather is filling the cylinders with water. Just keep this in mind.
Old Mar 28, 2015 | 06:21 AM
billymgb1000's Avatar
just a thought for what it costs for head gaskets and head bolts pull the heads lap the valves and do it for the experience.
Old Mar 28, 2015 | 06:36 AM
squalor's Avatar
Didn't you say you had a '02 LS1 ?
Old Mar 28, 2015 | 10:35 AM
Darth_V8r's Avatar
Moderator
Here's the deal on time --
It'll take you a couple hours to get the intake off, water pump off, front timing cover off and valve covers off.
Then, figure two to three for the actual swapping the cam part of the swap.
Then, figure another two to three hours for the valve springs - assuming you use TDC method AND have the right VS compressor.
Then, another three hours for reassembly.
For a first timer, if you have all the tools and parts you need, you can plan on 8-12 hours wheels up to wheels down. After you've done it once, the second job will only take 5-6 hours, because you'll have fought through all the battles and learned the tricks
Old Mar 28, 2015 | 12:41 PM
  #32
Gen 1 motors were used in a few vehicles till 2002 hence the year range on that cam. it WILL NOT work in a gen 3 motor.
Old Mar 30, 2015 | 08:51 PM
  #33
This won't work in ls1? Yes mine is an 02
Old Mar 30, 2015 | 09:56 PM
  #34
squalor's Avatar
No sir. Ls cams do not have a distributor gear. Different bearing journal diameter, other differences.
96capricemgr = Gen 1 motors were used in a few vehicles till 2002 hence the year range on that cam. it WILL NOT work in a gen 3 motor.
He's right, as usual. See, we saved you headache. You can send donations to help pull squalor from poverty to my PayPal address
The GMPP Hot Cam is close to those specs. Scroll down a bit and find that thread or let us pick a stick for you.
Old Mar 30, 2015 | 10:00 PM
  #35
Damn jegs labeling... Thanks
https://sdparts.com/details/gm-performance-parts/12480033
I like this idea ^
Old Mar 30, 2015 | 11:30 PM
  #36
squalor's Avatar
That set-up will last, like 50K or more. Nice gain from stock too.
Old Mar 31, 2015 | 07:02 AM
  #37
Sounds like a winner. I'm going to order today, thank you for the advice!
Old Mar 31, 2015 | 07:04 AM
  #38
This helps a lot for an estimation, thanks! Although I don't recall having to remove intake manifold, right?
Old Apr 2, 2015 | 11:29 AM
  #39
Darth_V8r's Avatar
Moderator
No, just the air box, MAF, throttle body. I re-read my post, and I just said "intake". I was referring to the ducting, etc, not the manifold
