99 T/A H/C swap checklist
Just want to make sure my buddy is not missing anything, so I'd appreciate if you could double check his list. The car has 180K miles on it, so If he's missing something let me know.
Thanks
BTR Stage 2 Cam Kit(Cam, Springs, Pushrods) - $719
Ported 243 heads - Used $900-1100
Fast 92(New) - $850
Nick Williams 92 TB - $370
A set of bigger injectors - $200-350
Injector O-rings $30
Cam install kit(Timing cover and water pump gaskets and damper seal, Timing set and chain, Crankshaft bolt) $120
Fast 92 intake port seals $24
NGK TR6 plugs $16
OEM Head gaskets - $40
Melling Oil Pump - $106
LS7 Lifters and retainers $150
OEM Header gaskets -$40
7 quarts of oil - $50-60
2 Jugs of coolant -$20-30
Thanks
Fast 92(New) - $850
NGK TR6 plugs $16
