317 home hand porting gone bad?
They look like thunderstruck507 rocker boss. He's getting good results from his heads. Remember to put some RTV on the end of the rocker bolts before torqueing them for the last time or you could draw oil into the port.
just be careful what you shape...without a flow bench it's easy to do more harm than good
I did not do the grinding on my heads, a local guy did them for me. Previously he had mildly worked on them but now that he has a flow bench he did more work. Ended up with 306cfm at .600" on a slightly oversized bore plate.
called a local shop and they said $250.00 to $500.00. I thought that was kinda pricey.
I figured just get these heads ported within reason.Don't want to spend my life on them. And I don't expect them to flow like the top porters out there.I just wanted to do this so I could learn something.
the price above. I was planning to take them to WCCH for a valve job and milling at some point.
