What do I do about this rust?
Old Apr 23, 2015 | 09:58 PM
dewchugr's Avatar
Default What do I do about this rust?
Old Apr 24, 2015 | 02:05 AM
Jontall's Avatar
Wipe it down with oil or ATF. Marvel Mystery Oil works well too. That motor should have been coated with oil before it was stored.
Old Apr 24, 2015 | 07:32 AM
KCS's Avatar
KCS
Moderator
You can use a wire wheel and something like WD40 to clean it off. A machine shop can blast if off too. I had a BBC blasted, cleaned, and checked for cracks for about $80.
Old Apr 24, 2015 | 11:21 PM
.boB's Avatar
Wire brush it off. The problem will come when you try to seal that area. That corrosion will make a pitted and irregular surface.
