Help! Engine is using massive amount of oil
Old May 13, 2015 | 01:41 PM
garethmarshall's Avatar
I would have a hard time believing that 7 quarts would be gone that fast. Either someone took the oil out or there wasn't enough put in to start with
Old May 13, 2015 | 04:02 PM
Old Geezer's Avatar
Aftermkt pan>>> Dipstick and tube match it?
Old May 14, 2015 | 06:24 AM
brandon6.0's Avatar
I had a oil problem with my last setup. I went and purchsed a new pcv valve at advance when i put my motor together. Well i ran that setup probably a good yr before i tore it down. The last time out with it i had a few detonation issues when on the spray. I figured the kit was getting old and used a good bit. Didnt worry about it to much. So i tore it down and what do ya know, when i pulled the heads the intake runners were full of oil. Alot of oil. I checked pcv and it was sloppy loose. So check that for sure.
I bet i was down on power alot with my last setup from burning oil like crazy and detonation!
Old May 14, 2015 | 05:01 PM
cmercer89's Avatar
Just a little update, it turns out that it wasn't seven quarts that I was missing. Talked to the guys who made my oil pan and cleared up some confusion. Still I'm missing about 3-4 quarts in less than a month. I'm going to drain the oil. Recheck my dip stick measurement and get a fresh oil Change. I'll update you guys again soon
Old May 14, 2015 | 05:02 PM
cmercer89's Avatar
I will definitely change the pvc stuff out. I'm almost positive it's original. So about 15 years old
Old May 14, 2015 | 06:05 PM
wayland1985's Avatar
What capacity is the oil pan?
And you said 800 miles, correct?
Old May 14, 2015 | 06:18 PM
RockinWs6's Avatar
Typical BS ...reason I don't answer many posts anymore. If you want help at least post something believeable. When I seen this thread that he was missing 7 qts I KNEW THE POST ABOVE WAS COMING!
He doesn't have a clue how much oil he's using etc...don't waste your time.
Old May 30, 2015 | 01:19 PM
cmercer89's Avatar
Wanted to give you guys an update, I found out that my valve covers do not have the baffles on the back side. So I'll be trying to find a set of those and see if that helps
Old May 30, 2015 | 01:24 PM
cmercer89's Avatar
Yeah I guess you're somewhat right. but I'm learning a lot from this car. I made a hasty post because I was freaking out. After I closer look I realized I was wrong.
Old May 30, 2015 | 03:56 PM
joecar's Avatar
From the pic, you have the old LS1 PCV plumbing (under acceleration oil furiously pumps up pushrods and floods valve covers, g-force throws it to the rear into the PCV plumbing which promptly ducts it into intake manifold)...
you need the valley cover PCV plate and a catchcan.
Old May 30, 2015 | 03:59 PM
joecar's Avatar
Also, it's a good idea to check oil level regularly (some of us do this at gasoline fill up; some of us do this before starting engine each day).
