I now know what it sounds like when pistons hit valves.
I bought the following heads from Richie Carbone:
98 ARE STAGE II heads
2.055 1.60 valves
Comp 987 double springs
Titanium retainers
11.0:1 compression (heads milled 0.60)
And the following cam from VINCE:
226 226 .584 .584 112 +4
With 7.350 Push rods from JPR.
It took me approx. 6 months to start the heads and cam swap, 2 days to complete and only a few seconds for the pistons to hammer the valves.
I should have clayed the motor to check the clearance, but I didn't and I payed the ultimate price. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
I take full responsibility for the error.
I just though you guys might want to hear how it went and maybe someone else will learn from my mistake - Take NO shortcuts! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Sterling.
2.055 1.60 valves
Titanium retainers
Sterling.
YIKES!@# I wish you'd posted that combo on the board before you fired it up. Just by looking at the parts listed you can tell it was gonna be reaaaaaaaaaaaly close. 60 thousanths milled heads, big intake valve, .584 lift, and 226 duration is just way to close for comfort.
Ah well, live and learn. Hopefully your pistons are ok and the heads just need to be re-done a little.
so, you got any soundclips? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> J/K
seriously, sorry to hear about that.
Steve
Steve
D(irecto)r Pepper
I have run a setup very similar to that combo, it can be done.
Though you really should take the time to check clearance.
THNAK YOU for posting your experiance...i hope some of the "bigger is better " genre reads your post and rethinks the "max compression-max lift-killer duration" path they are pondering on going down.
Thanks for the info amigo.Good luck on the rebuild.
Sorry to hear about that. You'll be up and running in no time.
I think you take the award for the first complete story as told by smilies!! That's too good!!
AZLS1:
I bet the heads actually had 2.08 intake valves. Did you measure them before the install?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GTP LS1:
<strong> AZLS1:
I bet the heads actually had 2.08 intake valves. Did you measure them before the install? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I did not measure them, but I will tomorrow.
<strong> AZLS1:
Damn that sucks. I hear ya though, once you get started on it, you wanna get the thing runnin and take a few shortcuts.
The pics of the emotional paths is too funny. Exactly how Id picture it.
Good luck getting it straighten out. Hopefully there isnt much damage. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Brian98:
<strong> sorry to hear about this...
i'm in the almost same situation......
i'm concerened with clarance myself,,i'm going to putty but before going that far anyone have suggestions
222/224 566/568 112Lsa
2.00intake/1.57ex
heads milled 0.30
push rods i'm unsure about i think stockers are 7.40???maybe go with 7.35's
any help here??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You should be fine as ur lift is smaller and the heads are not milled 60. But u can always check to make sure and see how much clearence u have. Good Luck and sorry to hear that man.
2.00intake/1.57ex
heads milled 0.30
Thank you for the support everybody.
I did actually try and get a sound clip of it, but it didn't work out.
I sounded alot like the Keebler elves were in the block hitting it with ballpeen hammers.
MY emotional path looked something like this:
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
2.00intake/1.57ex
heads milled 0.30
2.00intake/1.57ex
heads milled 0.30
LSX Mechanic
I did the same thing once, it was NOT pretty.
I wish you the best of luck, but I can tell you it's not going to be good. Hopefully you just bent some valves, but my little disaster turned into needing a new motor because of 3 cracked pistons. Definately not a pretty site after you just spent hours upon hours building the thing. Good luck though, hopefully yours won't be as bad as mine..
Josh
Josh
Where are you at in chandler. My sister live in the occitllo lake housing tract. Sorry to hear about the valves. I will be sure to clay mine before the install. I hope the damage is not too severe.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by strokedls1:
<strong> Where are you at in chandler. My sister live in the occitllo lake housing tract. Sorry to hear about the valves. I will be sure to clay mine before the install. I hope the damage is not too severe. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If she's hot I'll take her out...I'm about 5 mins away <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Sterling, it would really be a shame to rebuild that motor without resleeving it. I mean hell, you have to take it apart anyway, might as well make it worth your while! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Sorry to hear it, but I think that you could saved yourself from this disaster had to posted that setup on here... You had 4 things against you...big intake valve, .060 milled heads, .580+ lift, and 112LSA... Had you gone .030 over with 2.02 valves, and a slightly smaller cam, you woulda been okay...
Oh well, at least now you have an excuse for an ARE 382!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I have not decided whether I will change the cam or the heads.
The cam would be cheaper to replace, but since I can only get 91 octane 'tractor gas' at the pumps around here I am inclined to use the 5.3L truck casting ported by TEA and brng it down to 10.8:1 with stock 5.7L deck height.
Sorry to hear about the mishap <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> Good luck with getting her back up and running as soon as possible!
the best way to describe the sound was offered by my wife, who has been in the car when the old-style ARE heads seized a valve.
From inside the car, while driving, it sounds like someone suddenly shoved a bunch of tin playing cards into bicycle spokes.
Then the engine runs like complete poopie.
chris
chris
