Cammed guys: Where does your car idle?
Old Jun 4, 2004 | 12:20 AM
Mike94ZLT1's Avatar
Default Cammed guys: Where does your car idle?
Hey guys, how low can you get your car to idle? Mine currently idles around 800 RPM, but I'd like to go lower, to 750 or hey 700 if I could get away with it. Think its doable?
Old Jun 4, 2004 | 12:26 AM
Ed Blown Vert's Avatar
I have mine set @ 775
Z28Venom's Avatar
Mine is set at 920...
I wanted to go lower, but the cam wouldn't allow it.. The car would try to stall everytime I was going to a stop.
Old Jun 4, 2004 | 12:56 AM
Ferocity02's Avatar
Set to and idles well at 700
Old Jun 4, 2004 | 01:37 AM
Colonel's Avatar
This '02 idles smoothly at 500...heck, probably 400 (haven't tried that) and runs 11.20s NA with 3.23 gears at 3525 lbs. It also gets over 23 MPH averaging 80+ MPH. Big cams are HIGHLY overrated, IMO.
Old Jun 4, 2004 | 01:50 AM
01_SuperSlow's Avatar
My X2 idles at 900.
Old Jun 4, 2004 | 05:56 AM
98_1LE's Avatar
I have mine set at 1050 with the 231/237 cam, but I have an aluminum flywheel and lightweight pressure plate.
Old Jun 4, 2004 | 07:09 AM
WS666's Avatar
T-Rex at 900
Old Jun 4, 2004 | 07:40 AM
Windy City's Avatar
Keep working on your tune. I have my TR230 idling at 850.
Old Jun 4, 2004 | 07:44 AM
SS SLP2's Avatar
Y2K stock heads a4/3.23/stall, 22.9 mpg Idles great @ 625 with 231/237
Old Jun 4, 2004 | 07:54 AM
Country Boy's Avatar
Senior Member
900 with a bigger cam than the X3 and its smooth.... sorta
Old Jun 4, 2004 | 08:11 AM
gator's 99TA's Avatar
my 230/230 on a 111 lsa with an auto idles at 900 rpms. no stalling problems.
Old Jun 4, 2004 | 09:11 AM
soliari's Avatar
baby cam @ 725
Old Jun 4, 2004 | 09:18 AM
CamaroCain's Avatar
man I wish I had countless hours to spend time with our tuner. Our biggest problem is start up, especially cold start. I can't believe some of you guys can get your cars to idle 800-900 easy with your big cams.
Oh and to answer your question...based on what everyone else is saying and that fact that you have a pretty small cam I don't think it would have a problem idling around 750, especially if you can spend time with it getting it just right.
Old Jun 4, 2004 | 09:36 AM
foff667's Avatar
LS1TECH Sponsor
850-910 here
Old Jun 4, 2004 | 09:41 AM
Derek98z's Avatar
C2 @ 850, but am going to tune it lower.
Old Jun 4, 2004 | 09:53 AM
Classic's Avatar
3 cams -- all idled around 900 rpm, but would probably idle lower if I really wanted to.
X1, TSP231/237, and now my 235/239
Old Jun 4, 2004 | 11:09 AM
Orange Peel's Avatar
G5X3 114, set at 900-950 A/C off, 950-1000 A/C on.
Old Jun 4, 2004 | 11:22 AM
taqwache's Avatar
looks like i got the highest one. i use to idle perfect at 900 with the M6 and then i installed a TH400. i have idle problems ever since. now i am at 1050 with 2 hugh holes in the TB and an open loop idle. now it is almost perfect but still dies from time to time. although my cam is pretty hugh.
Old Jun 4, 2004 | 11:24 AM
2001CamaroGuy's Avatar
I set my TR224/224 112LSA to idle at 800 (stock M6 RPM). It "could" idle as low as 600 but it was almost impossible to drive (you had to really work it up to a stop).
For my new cam I'm hoping it needs to idle around 1000-1200RPM
