How much I can get with ls1 heads & cam
Hi everyone , I read a lot of thread & a lot of topics about heads & cams . when I read more i have been more confused & don't know what i should doing
I have 96 impala with ls1 & t56 bolts on already
my goals beat a few cars of my friends 1- charger 2014 srt 8 bolts on or stock
2- lexus 2014 isf bolts on
3- mustang 5.0 liter bolts on
I don't care how much it's cost me my budget is open to beat them but I don't want to waste my money and still can't beat them I love to do it N/A .
It's possible with N/A ls1 ? or I should change my engine .
I really need a pro advise .
You can get 420whp-450whp with a head/cam combo. If you're looking for 500whp its going to be a very radical setup.
I highly recommend a supercharger or turbo charger kit. With that said, if you are stuck on going N/A and want big power you might want to look at the lq9 block. Bore it, stroke it, forge it, get a badass cam, set of heads and a good intake.
Good luck
Good luck
The problem is the Impala is heavy. Do to the weight of it, it's hard to say if a H/C/I package will be enough. Honestly, I would go with a supercharger for your application.
Good luck
Good luck
thanks man , I think 450 not enough to beat that cars . It's not easy to have lq9 here and it's but I think about ls2 or any 6.0 liter , I don't want to change mine untill I know is there no other options because that's make me rebulid every thing again . What if i stroke my ls1 & get heads & cam ? is that still not enough ?
The reason I ask is because it can get very expensive and time intensive.
They make procharger kits that literally bolt right up, you load a "canned tune" and bam, you have 500whp.
Remember that your t56 needs to be built too. With your added weight, that transmission is going to be under much more stress. Also, with added power you will need a better clutch.
You CAN bore out a ls1 but I highly recommend switching to a iron block, but you mention you may have difficulties locating certain engines in your area?
yes man I know the biggest problem the weight , I keep super or turbo in my mind but which choice is better get 6.0 liter engine and do cam & heads or just get turbo or super with mine .
This is why I recommended a basic nitrous setup and do a small 75-100 shot. That way you'll have that extra insurance in case the HCI isn't enough to beat those cars cars n/a
Are you absolutely set on going N/A ?
A think the trans can handle untill 600 whp right ? I have stage 2 clutch from corvette , is it enough or I should replace that too ?
About iron block I can't find one with good price here the second problem with iron block is the heat it's too hot here that's was my problem with lt1
If I stroke , bore mine & get procharge or turbo how much power I get ? can I beat that's cars ? is this option better than get 6.0 liter with heads & cam ?
What I want the best price option( my budget is open but I hate to waste my money if I don't have to ) & try to keep the car daily drive .
My problem with gas is I never use it before & I try to build car for a long time I never think to sale this car . I know maybe the best offer to save money heads & cam with gas but I don't love it .
Conversely, I had 420whp and 370tq and walked gt500's (stock) all day long. Weight is huge. Huge weight needs huge tq.
Where are you? Europe is a hard *** market for finding LS anything. Usually have to hunt around a US base or pick one up at a big expense from the airport. I would have swapped out my LS1 by now if I were back in the US. Maybe 2017....
that's why I want to change my ls1 to 6. liter but I read so many thread that's make I respective number around 500 whp on ls1 .
I really want the best option : get 6 liter, heads & cam or go with forced power with mine , I think I can't beat them with just heads & cam on ls1 right ?
do u think it's better swap ls1 with 6.0 liter ? or stroked & used forced power with my ls1 ?
from what I read I understand I can't beat them with just heads & cam .
Start Here .... https://ls1tech.com/forums/generation-iii-internal-engine/1761226-optimized-346-build-227-cam-almost-490-rwhp.html
I'm in the middle east they have alot of ls1 and more of 6.0 liter l98 ,l77 but ls3 is so expensive & hard to find . I have i good budget but I don't find the best deal , the best way to beat that car & save money in the same time .
I can't find any other Ls engine .
