LS lifters and thick oil...
Old Jun 6, 2015 | 10:08 AM
ButchB's Avatar
Default LS lifters and thick oil...
What is the heaviest weight oil I can run without running into problems with my lifters? I have the comp lifters. I need to run a thicker oil if possible but am hearing the LS lifters have problems with any of the thicker oils. Thanks in advance for any info on this.
Old Jun 6, 2015 | 11:45 AM
RockinWs6's Avatar
Anything above 30 weight makes mine worse, I add a few ozs of ATF which really helps the lifter noise. I tried 10-40 and the lifters really got crazy loud.
Old Jun 6, 2015 | 12:06 PM
1989GTA's Avatar
I have been running Joe Gibbs 10W40 break in oil and no problems with the lifters. This is a conventional oil with a lot of ZDDP.
Old Jun 6, 2015 | 12:29 PM
kinglt-1's Avatar
Running morel 5315 lifters with 5w40 valvoline synpower euro formula and no issues.
Fyi LS lifters are the same as SBC lifters. That is one of the few parts that never changed design. SBC, Gen 2 LT1, Gen 3 & 4 LS all use the same style of lifter. Bearing tolerances are what determine oil thickness to run anyway. Many race motors are built with wider bearing tolerances to run 20w50 race oils....SBE LS stuff is normally fine with 30&40 weight synthetics.
Old Jun 6, 2015 | 01:34 PM
LS1-450's Avatar
As in post 4 above, bearing clearance determines oil viscosity. Why do you need to run thicker oil? Most 30-40's hold their viscosity up through 230*F actual engine oil temps. Unless on road course, oil temps generally run 15-20*F lower than coolant temps. Only time we use 20W-50 is on road course where oil temps can reach 300*F.
Old Jun 7, 2015 | 01:17 AM
RockinWs6's Avatar
Yes it may be the same style lifter but its NOT the same lifter. Some years the LS1 lifters were poorly matched and bleed down way fast. I have a 01 and the lifters get very noisy with heavier oil. I'm not talking ticking and tapping, they actually start to RATTLE every time the cam train unloads using heavier oil. I tried 10-40 once and the engine rattled so bad on deceleration I changed it back to 5-30 within a 100 miles.
Now if you don't have the stupid azz fast bleeding lifters your experience probably will be completely different. ALL of my 5 LS1 cars had these lifter bleed down problems and running heavier oil didn't help any of them. My experience says a lighter oil helps, adding 8 ozs of ATF to 5-30 quiets my lifters quite a bit. But ATF is hydraulic oil and its thin enough to get into the lifters fast enough to keep them free of air. regular engine oil is slower getting in there.
GM dealer fix for noisy lifters for years was to add ATF to the engine oil.
Another thing you may want to try is a high quality synthetic oil like Castrol Edge. It very thin and can get in to the lifters easier to get the air out and keep them quiet. Also thin oil may result in lower oil pressure because it bleeds past the bearings faster but it also results in cooler running bearings because of the added oil flow past the bearings.
Old Jun 7, 2015 | 03:17 AM
TA63's Avatar
Lol. I would love to see the official GM bulletin that advised adding ATF to motor oil. What a joke.
Old Jun 7, 2015 | 07:08 AM
mikesimpalass's Avatar
Just to add a little to this thread, I use ls7 lifters in my engine and I run conventional 20w50. I don't have any noise or problems.
Old Jun 7, 2015 | 09:12 AM
kinglt-1's Avatar
I have a 02 that had no issue with 5w40 synthetic with stock lifters. It actually was less noisy then with mobil 1 5w30.
Old Jun 7, 2015 | 09:39 AM
Darth_V8r's Avatar
Moderator
I talked to my tuner about it and he said he sees the best overall results with 0w-40 on LS motors. Given the sheer number he sees, I'll be giving that a go next oil change
Old Jun 7, 2015 | 03:27 PM
patSS/00's Avatar
Same oil, stock lifters, no problem.
Old Jun 7, 2015 | 08:27 PM
RockinWs6's Avatar
AAhem....I was the Service Manager.................it works quite well by the way.
Old Jun 8, 2015 | 08:51 AM
thunderstruck507's Avatar
I've ran the earlier vortec 350 lifters in my ls1 and now using ls7 in my ls2. No issues with 0w40 Castrol Syntec (the current made in Germany oil)
Old Jun 8, 2015 | 09:03 AM
elephantrider's Avatar
you know thats a detractor from your credibility even more,
than if you just said you read it on the interwebz.
Old Jun 8, 2015 | 12:31 PM
RockinWs6's Avatar
Yeah bull ****, people don't want to know what really goes on. Bet your mother never s......... never mind.
Old Jun 8, 2015 | 01:19 PM
JakeFusion's Avatar
Super Hulk Smash
If you're on a stock motor, you could use something like Valvoline VR1 10W30.
Old Jun 8, 2015 | 03:29 PM
your just reinforcing the "service manager" stereotype
..and yes i'm sure my mom did, as did your mom.
...and dad in college.
Old Jun 9, 2015 | 04:03 PM
RockinWs6's Avatar
I put ATF in mine every 2 k or so, stays nice and quiet.
Old Jun 11, 2015 | 08:18 PM
skypuppy99's Avatar
yeah you probably got that run ATF in your oil back when they used to do that in the old diesel engines to keep the injector pump and injectors cleaner. I run Mobil 1 and have for 188000 miles and never had any lifter noises. years ago GM did have a bulletin to run mobile 1 in a engine for a noisy lifers or piston slap. after when it was time to change the oil then go back to what the customer was using before. the thicker the oil the harder it is to get to the parts that needs the lubrication. that's why GM got away from 10-40 oil and went to 5-30. because they bought a lot of cams back in the 70"s
Old Jun 11, 2015 | 08:57 PM
RockinWs6's Avatar
The bad cams were from improper heat treating on the lobes. Some lobes were too soft and would fail.
Back to LS1 lifter noise, mine can be noisy as hell. If I add about 8 ozs of ATF DexIV its quiet as a mouse for a long time. That alone tells you thinner oils helps lifter noise in these engines. Part of the problem is it takes so dam long to get the oil up into the gallery AND the lifters bleed off way too fast.
