Help identifying this engine
i want help to identify this engine,I hope some of you can help, and im want convert this EFI engine to carburated, u can say me the type of ignition controller to use and type of reluctor wheel 24x or 58x
Thank you
5.3 12571048
799
i have a doubt... im looking on Jegs for MSD 6012 and says:
Ignition Controllers
Engine ID:
LS2/LS7 Cam sensor in front. Gray crank sensor connector.
LS1/LS6 Cam sensor in rear. Black crank sensor connector.
The cam sensor for this engine is in rear but the crank sensor is gray
It appears to have the later "TBSS" intake manifold
AND
It appears to have the plug for the oil control manifold
AND
The non-return fuel line
AND
The later DBW throttle body
Would all indicate this is a GenIV engine that would have a 58x/4x PCM.
AND
AND
AND
Thank you
The earlier Gen IIIs had the "5.3" heads which I forget what casting they were but also had iron blocks.
If theres a hole through the center of the oilpan for the front axle its a dead giveaway http://www.ls-guy.com/lh6/
ALL v8 360's vehicles (Trailblazers, Envoys etc) came with all aluminum engines. From 03-09 Obviously the LS2 trailblazer but all the 5.3's as well. These 5.3's were built for the 360 platform only and included the LM4 Gen III (03-04)and LH6 Gen IV (05-09). The 05 later V8 came with actual stamped 243 heads. I've owned 2 so I think I know what I'm talking about. If you have evidence to prove otherwise please post it.
ok, but that's a Silverado. Trailblazers were packaged differently, that's the point I'm trying to make. I think the only other vehicle the LM4 came in was the SSR.
This from the SSR site "Chevy's new roadster is powered by an all-aluminum Vortec 5300 V-8." This is the LM4 and was never an Iron block nor was it offered in the Silverado. The package was made for the 360-370 platform (SSR,Trailblazer etc)
Yes, but all the LH6's I have seen came with the 243 heads. Now is it possible that they ran low on 243's and threw some 799's in on some vehicles, maybe. Your Rainer was an 04 right? So which heads came on that engine?
Do you have a picture for reference? There isn't a lot of info on these engines so I just go by what I see. If you say it has 862's I believe you, but it would be nice to have an actual reference. Also, could you take a picture of the Left rear of the block just below the cylinder head? The Vin should be etched on the block to confirm it.
Also trying to get a hold of my brother to see what heads are on his truck cause he just bought a 09 9-7x w/ 5.3 2 weeks ago
As far as I know the 799 heads didnt come out until '05, when they started on the L33's.
I reference the 243's from the old 06 I used to drive. That is what I based my post on. Now obviously I am mistaken because there seems to be a couple different heads floating around on them. I learn something new everyday.
