anyone running the hawksthirdgen head/cam package?
I'm not talking about off idle, I'm saying cruising around. If you getting cam surge from lets say 1300-1600rpms and you pull timing to get rid of it...that's 30hp or so your down in that rpm range.
At idle sitting at a light the cam is fine..i've had no problems with it there at all.
side note if I decide to break my build up into 2 pieces. What kind of power/ times can I expect with tSP 1-7/8 LT , catless y, SLP Lid, slp LM exhaust, and some 4.10 or 4.56 gears ? and a tune
im an M6. also what are people revving at on highway speeds like 70-80 in 6th with the higher gears?
power should be 340-360whp low 12 sec car maybe touch 11's with a little weight loss.
I run 3.90s and spin 1950 at 80....i think 4.10s are a little short. first gear is never really used as its so quick. the 3.90s are a good middle ground between 4.10 and 3.73
I think I am going to do this in the 2 parts as mentioned.
because I would like to do poly mounts, and some suspension work as well so that gives me the opportunity to do it and then save up for the H/C/I portion down the road.
Well, now your just contradicting yourself.
In the manual cars ive ridden in with reasonable sized cams they drove near stock, most had gears as a supporting mod. With bigger cams, I wouldnt expect the manners of a small or stock sized cam. There is a certain point where a cams manners become a cams manners. Nature of the beast. The clarity part was when I said perspective. I used the word stock twice and thats where you got confused. I should have said "tame". Big cams can be tame. Meaning smooth low end, no bucking, no surging etc. But no way way a big cam will pull the dead nuts low rpms that some people are used to by a stock setup.
Whatever...all I was saying is with the toquer cam it's a bitch to tune and you'll end up pulling timing to get rid of the surge. I know cuz I've been all over it with my tuner. I've ridden in cars with cams in the 240's on both sides that ran better / easier to tune than them. That's all i'm saying...damn.
