anyone running the hawksthirdgen head/cam package?
http://www.hawksthirdgenparts.com/ls...ceted_search=0
thanks in advance for your feedback
http://www.texas-speed.com/p-4346-pr...-outright.aspx
I am going to prob get it from texas-speed since it is their parts. but regardless want to know if anyone is running this package and what there results are.
also the hawks question is because they have the front grill that I like and a few other parts
what did you run with the car?
i am just planning out everything I want to do and been doing bits n pieces when I can
In 1 shot I will prob do heads/cam combo , LT Headers, motor mounts, trans mount, plugs wires and tune
If you're worried about sound, don't the exhaust has a large effect on how a cam sounds and pretty much any small-medium can will chop pretty well.
Personally I'd look at the torquer v4 it's very similar to the v3 but the lobes are smoother and will make for an easier job on the valvetrain.
For an oil pump a ported ls6 or HV/HP melting unit will work nicely and is affordable. For the timing set, just get a new gm ls2. It's more than you'll ever need and is cheap. If you wanted to I would pick up the trick flow timing chain damper, that's far better money spent than on an aftermarket chain
TSP 1-7/8 LT headers , catless y-pipe , SLP LM1 , SLP lid , poly motor and trans mount, MGW short throw shifter , 4.10 or 4.56 gears, the 2.5 5.3 head/cam pack from texas speed.
