Difference between 2001 Camaro LS1 and Corvette LS6
I was lucky enough to receive the LS6 block in my car. I know that the block and heads are the same, and that the heads are different. What are the internal differences in these motors? I would like to fully upgrade this engine to atleast a stock LS6. What will I need to do this, besides the heads? Looking to get it ready to swap into a '57 Corvette.
Oh and springs also, not sure if you accounted for those when you said complete heads.
I'm not sure of the cam specs. The guy I got it from had it custom ground from Comp Cams. I may be able to get the specs from him, if not, when the car is dyno tuned it shouldn't be an issue if I don't have the specs, right?
Part numbers are exactly the same.
http://www.trademotion.com/parts/200...&siteid=214858
https://ls1tech.com/forums/generatio...s6-intake.html
[url]http://www.trademotion.com/parts/2001/Chevrolet/Corvette/Z06/index.cfm?action=partDetail§ion=ENGINE&group=P ISTONS%2C%20RINGS%20%26%20BEARINGS&subgroup=PISTON S%2C%20RINGS%20%26%20BEARINGS&component=PISTON&par tnumber=88984245&vehicleid=13971&siteid=214858[/url
12561184
12573572
I have seen both part numbers on multiple vehicles.
