5.3L advice
5.3L advice
I'm looking what everyone thinks about this. I'm building a 74 nova and I found this motor and just looking for advice, I'm brand new to the LS world.
5.3L out of a 03 Tahoe with around 80k miles and not sure what tranny he has I have not seen it yet. But no harness or accessories on the motor. $1200
Thanks for the help
Matt
Thanks for the help
Matt
I haven't got it yet I'm going to go look at in a few days when I get off work. But my plan is to throw some upgrades on it. Not a 100% yet on what I will do until I get one. But I will be a fun and a good learning experience.
Also, double check that the truck intake manifold clears the hood. Might need to go to a LS6 or aftermarket intake. Don't go to a LS1 intake, as the truck intake flows better.
Look into a higher stall speed converter to help with acceleration. When you do the above and then get a tune, the tuner can program the converter lock accordingly, so it will still drive OK.
All that without touching the internals of the motor and you'll run well.
You'll definitely want long tube headers.
What range on the stall would be good?
Cam look at the brian tooley truck stage 3 cam. Get his platnium duel valve spring kit and some of his pushrods and be golden.
If you can streach it get som 243/799 heads and have them milled 0.030" to around 59-60cc chambers.
Also that transmission looks like a 4wd 4l60e missing the transfer case.
