What oil pump and timing chain?
For a chain, I went with the ProGear set, around $100. A step up from the LS2 chain. If you do go with the LS2 and find it has slack when you install it, you can get the trick flow chain damper adapter that would take up some of the slack. Might make your chain last longer too.
A run of the mill quality part will work fine. An off the shelf Cloyes hex adjust timing chain kit adds complexity but is a quality part. An OEM LS2 chain works great as well.
A LS6 oil pump with supplied with o-rings is better than the OEM LS1 pump by default. Spending 30 minutes porting the intake side with a dremel tool and the DIY instructions on this website and it will be better by default so long as you don't ruin the oring sealing surface. Add some washers to the bypass spring per the same DIY instructions and your oil pressure will be higher. An off the shelf high pressure Melling is nice but also more expensive than a DIY port LS6.
