LS1 Vs LQ9 Procharged
Old Jun 26, 2015 | 02:18 AM
MidnightDynamite's Avatar
Default LS1 Vs LQ9 Procharged
Plan for build is around 600 rwhp. Would I be better off forging the ls1 or starting from scratch with a LQ4/9? Balling on a budget but still want reliability.
Old Jun 26, 2015 | 04:30 AM
Exidous's Avatar
How important is weight to you? If you are after "only" 600whp I'd say forged rods and pistons on the LS1. Stock crank.
Old Jun 26, 2015 | 05:19 AM
HCI2000SS's Avatar
At that power level either one is totally fine
Old Jun 26, 2015 | 07:32 AM
Rise of the Phoenix's Avatar
At that level, you can run a LS1 or LQ9 in stock form and be fine.
Old Jun 26, 2015 | 07:59 AM
kinglt-1's Avatar
Save weight and keep the aluminum block.
Old Jun 26, 2015 | 08:54 AM
MonmouthCtyLS7's Avatar
I would just throw rods and pistons in the LS1
Old Jun 26, 2015 | 10:14 AM
I really don't see the point. There are countless non-forged LS1's out there running Procharged setups making far more than 600 hp and living just fine. As long as you have a good tune, you'll be fine. And if it does let go, you can always forge it then.
Old Jun 26, 2015 | 04:33 PM
Exidous's Avatar
Unless the block has a new window. :-) I agree that a good tune will work well on a stock ls1 but having the safety of the forged rods and pistons is worth it...imo.
Old Jun 26, 2015 | 06:25 PM
whatsa347's Avatar
Yup, I've seen way too many blow up around here to care, and that's WITH arguably the best tuners in the nation. You can control some things, fuel quality and other factors you cannot.
Old Jun 26, 2015 | 07:13 PM
30th t/a's Avatar
Yea...If your running E85.
600rwhp and 93 octane is a time bomb just waiting to go off.
If your running 93 octane, a forged 347 is what Id do.
Id keep the compression 10.1, to keep the throttle response nice and crisp.
Low compression with forced induction makes for a slugglish ride in the low RPMs. Been there done that, Not fun!
The extra cubes of the LQ9 is offset by the extra 80lbs of weight. Again, Been there, done that.
Old Jun 27, 2015 | 10:29 AM
kinglt-1's Avatar
If it lets go more then likely you will be buying a new block. Lol
Old Jul 3, 2015 | 11:20 PM
So down the road if I want say 800rwhp I'd be hard pressed to go the LQ9 408 route.
Old Jul 4, 2015 | 04:18 PM
Exidous's Avatar
Forged ls1 will do 800rwhp on boost obviously. 383 even better.
