Question about a cam i bought used...
Old Jun 27, 2015 | 01:43 PM
Matt Mayberry's Avatar
Default Question about a cam i bought used...
I recently bought a used cam, and would like to know some opinions about it. I am wondering if anyone else is using this grind. Any feed back is appreciated, and here are the specs.
Int. lift=.610
Exh. Iift= .613
Int. duration= 223
Exh. duration= 230
lsa= 113
Old Jun 27, 2015 | 01:58 PM
Darth_V8r's Avatar
Moderator
Are you able to match the cam serial number with the cam card or a cam Dr report?
Bad experience with a used cam
Old Jun 27, 2015 | 02:35 PM
Ya.... Those numbers were from the cam card, and I got the card based on the serial numbers from the back of the cam. It is a comp cam.
Old Jan 10, 2016 | 07:10 PM
Any suggestions or speculations at all? . I am just curious about how it will run, and it's behavior.
Old Jan 10, 2016 | 07:19 PM
HCI2000SS's Avatar
That's a pretty mild cam. What vehicle, trans, and mods?
Old Jan 10, 2016 | 07:35 PM
It's going in a 2001 trans am. The motor is a 6.0 with ported 243,s. The transmission is a 4l80e with a 3500 stall. I have the factory 3.23 rear end. I have headers, and an ls6 intake for it also. I am just trying to get some ideas for how it will do.
Old Jan 10, 2016 | 07:39 PM
HCI2000SS's Avatar
Should do ok, but that 6.0 and ported 243's can take a cam much bigger and make quite a bit more power
Old Jan 10, 2016 | 07:45 PM
I may just have to buy a bigger one. I am going to try and get close to the 450rwhp range.
Old Jan 11, 2016 | 07:23 AM
TXZ28LS1's Avatar
Need a bigger cam than what you have. But i wouldnt suggest putting a used cam in my car. Thats just me.
Old Jan 11, 2016 | 03:41 PM
Aston Tibs's Avatar
My Comp cam is almost exactly the same 223/231 .610/.617 and make 400 RWHP on a 5.7L. Decent idle and good vacuum with Stage 2.5 5.3L Texas Speed heads. Real nice mid range power. Pushed my 68 Camaro to a 12.37 on street tires. If you go on my build thread, I have idle and full throttle videos.
Old Jan 16, 2016 | 10:48 AM
Cool videos....... . Thanks for the help everyone.
