What Cam should I go with?
I need a good DD or maybe still a almost everyday driver. I have 1 7/8 longtubes, not cats, full 3 in.
It's between Texas speed 224r cam. Specs 224/224 .581/.581 112 LSA or 114
Or Brian Tooley Racing Truck Cam III. Specs 218/224 .533/.533 113+3
I wanna make close too 400whp or mid 350s or more, but still be a DD type and not have to run race gas. Or boost it. Any other cam suggestions or suggestions with a cam/head package or intake. Please help!
Ported stock or 243 heads.
Mamo Ported Fast RSXT Truck intake would add a bunch of HP & Torque.
The combo would add a huge amount of power & torque everywhere
In the power band 1500-5500 RPM only downside is cost.
To do all that with a 5.3, you'll want boost or nitrous. Or you'll spend the kind of money the 5.7 guys pay to hit 500 just to hit 400 and be daily drive able. You'll want AFR 205 heads, worked over by Tony Mamo, cam would be in the 222/226 113+4 range. Top notch springs, lifters, rods. $ee where thi$ i$ going?
If you truly want 400 to the wheels NA, you need displacement. swap in a used 6.0 short block, 243 heads mildly ported, tick SNS torque max S2 cam. You'll keep your low end and hit your top end goals and it'll be very daily drivable.
Cost doesn't really matter to me because I have a close friend that works and a machine shop and they port heads and do all that stuff anyways, and he can get me discounts on some of the parts too!
I kinda thought that would be a big show to fit at 400 rwhp just didn't know if I could do it and be practical for a DD.
If I did go with an 6.0, does it matter if I get the LQ4 or an LQ9 which are found in SSS? I would tear it down and rebuilt it anyways, so I guess I can change some things out but maybe the bore size of different or just a cam?
I have a 2wd Silverado with 3.73s along with full 1 1/7 long tubes with 3 in and it pulls pretty good already but if the LQ9 will pull even hard and make 400-420 easily. Than that sounds like the way Imma go. Any recommendations with any lifters or rods or springs I should run along with it?
If you pick up an lq4 or lq9 and then throw a small cam in and you will easily approach 400whp. The bottom ends on the lq4 and the lq9 are a tad different depending on the year but both are plenty strong. The lq4 though has dished Pistons which lowers compression which is the largest difference.
For the heads, if I was long term going to go ported 243/799 I would get the heads, get the work done, and stick them on. Then, when I got the short lock I could just transfer the heads. Heck even transfer the cam for initial start up. For a cam swap for the 6.0 down the road, I would go cam motion Titan 4 or tick SNS torque 2. Both are 227 duration, which gives a great blend of torque and power. Mine is actually a split between those two cams because I couldn't decide between them. Whichever vendor you go with will make better hardware recommendations than I will.
If I was going to go all out, I wouldn't spend a dime on the 5.3, and I would put the money toward the heads for the 6.0.
Update: Found the article - Here is the link.
