LM7 questions regarding refresh/rebuild
Higher compression, say something mild like 10.5:1, would help with spool and throttle response and torque production.
Low compression for boost is small block Ford tradition, it's absolutely unnecessary in the LSx world. Lots and lots of successful 11+:1 compression ls motors running plenty of boost.
Just make sure your squish/quench and tune are closer to perfect.
15-20psi on pump gas warrants a drop in compression, for sure. Glad to see you have your ducks in a row. Carry on, and keep us posted.
You can have the machine shop check the tolerances and if all is good put some new bearings in and put it back together with the stock rotating aseembly and new rings.
And good for you choosing great heads for a turbo motor, it matters.
Your hot side pipe sizing, layout, and exh housing will determine spool. That along with fueling and timing from pre boost through 3 psi or so.
After dialing all that in on my car, it actually spools too fast for the track conditions we normally see....😊
Have fun.
