LM7 questions regarding refresh/rebuild
Goal 1: Get the engine down to just the short block.
Goal 2: Tear down the short block
Goal 3: Clean up the block/parts
Goal 4: Add new main/rod bearings, piston rings (gapped for boost).
Goal 5: Reassemble the short block (re-using stock crank, rods, pistons)
This is what I'm focusing on for now.
Goal 4/5 has me worried because it seems everything is about clearances, measuring, and thousandths of inches. Anybody have any tips on the best way to go about this?
After removing most of the top end stuff was left with this
After removing first head (passenger side) instant
Cleaned out the water/sludge and this is what it looked like
After some cleaning
The cylinder is rough in that spot but no scratches and nothing gets caught when rubbing against it. Will have to tear it down to the bare block then take it to the machine shop. Might have to bore the block to 3.79 and throw in some wiseco forged slugs in there.
Sending the stock heads to be ported.
How it sits now
1) Custom pistons with a smaller dish
2) Custom MLS head gasket
3) Mill the heads
4) Deck the block
It looks like the easiest and most cost effective solution is a custom MLS head gasket with a compressed thickness of .030. What are some of the pros and cons of each of these methods? Any I should stay away from?
That spot in the cylinder may smooth out with a simple hone, so you may not have to over bore it at all.
Don't be afraid of putting it together yourself. Either buy or rent the proper tools. Make sure everything is clean and organized. And have a notebook handy to take notes, write down measurements, and label things.
You're clearly smart enough to establish steps for your rebuild, so now make sub-steps for those. Keep making checklists. Keep it as straightforward as possible. And try maintain some semblance of organization.
Milling the heads is a one time affair, and it allows you to use off the shelf gaskets.
Boost needs heavy duty valve springs. Heavy duty valve springs need heavy duty pushrods.
I still think that milling the heads for a 59-60c combustion chamber while you are already having them ported is the best way to address raising compression.
Or, maybe find a good set of GenIV 5.3 rods and flat-top pistons and throw them in there, assuming that the block doesn't need to be over bored. Even with flat tops, I would still mill the heads, for 11:1 compression, but that's just me.
as for milling heads or thinner gasket you need to research about quench and squish.
would also get that block checked out and see if its ok for boost.
The days of intentionally dropping compression for boost are behind us.
. Not sure what the reason is but i hope all is ok.Below are some pics of what it looks like now.
Decking the heads makes the combustion chamber smaller, raising compression regardless of quench.
Im going to bring my lm7 block to the shop and im trying to figure out what all i should have done to the block.
I want to retain as much factory specs as i can. Just wondering what all people normally have done to their block and crank.
You can have the machine shop check the tolerances and if all is good put some new bearings in and put it back together with the stock rotating aseembly and new rings.
