MMS 220 Build for "Ghost Hawk"
Old Dec 22, 2016 | 09:52 AM
  #521
BREWS02WS6's Avatar
Originally Posted by 98_WS6_M6
Lol. That's awesome too. And silver is very fast but just to let you guys know, black is faster
I can confirm that white is one of the slowest color options.
Old Dec 22, 2016 | 06:24 PM
  #522
NHRAFORMULA00's Avatar
Originally Posted by Firebirdmuscle
SO chris is your son huh? I believe that was Chris's car anyway Father, son duo. I like it. His car is awesome.
Winner Winner chicken dinner, you are correct sir he is my son.
Old Dec 24, 2016 | 09:40 AM
  #523
corysmach1's Avatar
Originally Posted by NHRAFORMULA00
https://www.youtube.com/watch?v=fj3jv9flSig
This is what happens with 522 R.W.H.P and 2,950 weight.
My son Chris car.
Nice. Good to see father and son at the track together.
Old Dec 26, 2016 | 10:49 PM
  #524
Darth_V8r's Avatar
Moderator
So, here's the MSD installation. Anyone who has read all the fitment horror stories - I had none. It just dropped right in. I found it easier to get my hands back there and work vs the fast. You gotta take it apart to drill out the hole for the map sensor and then reassemble it. No big deal, just gotta do it.
Here's some **** for your next happy time alone.
Basically, I tried to get pictures through the runners so you can see there's direct line of sight from valve to plenum. There are trumpets on the ends of the runners for max air velocity. There are three map locations you can use, but you gotta drill the one you want. No clearance issues between TB and meziere. The throttle is angled up about ten degrees.
Only issue was the lack of a throttle cable bracket which is sold separately. In my mind that's a bit weak. But it's the only complaint I had. Would have been driven today if I coulda hooked up the throttle.
Anyway, enjoy. The entire swap took four hours and forty minutes and I was taking my sweet time. Not even a hint of hurrying.
Attached Thumbnails MMS 220 Build for "Ghost Hawk"-photo722.jpg   MMS 220 Build for "Ghost Hawk"-photo727.jpg   MMS 220 Build for "Ghost Hawk"-photo241.jpg   MMS 220 Build for "Ghost Hawk"-photo41.jpg   MMS 220 Build for "Ghost Hawk"-photo670.jpg
MMS 220 Build for "Ghost Hawk"-photo333.jpg   MMS 220 Build for "Ghost Hawk"-photo862.jpg   MMS 220 Build for "Ghost Hawk"-photo344.jpg   MMS 220 Build for "Ghost Hawk"-photo284.jpg   MMS 220 Build for "Ghost Hawk"-photo582.jpg
MMS 220 Build for "Ghost Hawk"-photo63.jpg   MMS 220 Build for "Ghost Hawk"-photo629.jpg   MMS 220 Build for "Ghost Hawk"-photo817.jpg   MMS 220 Build for "Ghost Hawk"-photo906.jpg   MMS 220 Build for "Ghost Hawk"-photo373.jpg
Old Dec 26, 2016 | 11:08 PM
  #525
TheeCamaroKid's Avatar
Get your intake of you wifes kitchen counter!
Old Dec 27, 2016 | 07:24 AM
  #526
BREWS02WS6's Avatar
Can't wait to hear your first impressions and get some results!
Old Dec 27, 2016 | 08:22 AM
  #527
Firebirdmuscle's Avatar
Darth is the third to last pic, what's the little red piece thru what appears like a chipped / cracked hole? Trying to decifer what that is. I see all the bottom of the runners have this little hole.
Old Dec 27, 2016 | 09:44 AM
  #528
Darth_V8r's Avatar
Moderator
The red **** is a camera artifact. I never noticed in until you said something.
The slightly crack-looking thing as actually just a seam in the plastic. The flash made it really stand out, but you can hardly feel it. That hole is the injector port (the intake was upside down).
It's kind of weird, because it's a hole drilled into an angled surface, but when you see it in person and feel it, it makes sense what it is.
Its definitely NOT cracked. I ran the car on the new intake for a good 30 minutes to check idle air from cold to hot on a start up. Idled too steady to be a vacuum leak.
Edit - attached video is first start up on ported MSD. No tuning performed. Idled quite nicely. This was still quite cold. had only been running a minute, in 50 degree weather on SD tune. With IAT sensor disconnected, because the airbox was disconnected.
File Type: mov
Last edited by Darth_V8r; Dec 27, 2016 at 09:49 AM. Reason: Added video of first start up
Old Dec 27, 2016 | 11:10 AM
  #529
Darth_V8r's Avatar
Moderator
Here's a better pic to show you what you're seeing without that artifact
Old Dec 27, 2016 | 11:14 AM
  #530
98_WS6_M6's Avatar
Damn that car sounds good! Great work Jake! Can't wait to see it on the dyno again
Old Dec 27, 2016 | 11:41 PM
  #531
blk00ss's Avatar
I'm glad it was rather painless, but man is that thing ugly lol. If it does make more power that's all that matters tho! And it looks like Toby would had drilled the intake for the map sensor when he had it apart. So all you would have to do is bolt it on.
Old Dec 27, 2016 | 11:55 PM
  #532
Okay. That new pics makes it better darth. I agree that intake is not the best looking one there is but the power curve will improve with it. Now it's time to see the updated numbers.
Old Dec 28, 2016 | 08:42 AM
  #533
Darth_V8r's Avatar
Moderator
Thanks A A Ron! I'm extremely curious your build's numbers. NA motor, not the hotter sexier blown motor.
Drilling the map hole was no big deal. It has three places to drill, and Tony likely didn't know if I was thinking to move the MAP sensor. And yeah, Power>aesthetics. I was really only miffed by the lack of the cable bracket - which MSD sells separately, which is weak IMO. Cause I'd have already got some logs on it and known if the tune was gonna shift any, but I don't. Should get the bracket today
I'm hoping to get the numbers Friday. I've been in contact with the operator, and he's been saying all good. I'm just waiting to hear back on my Thursday/Friday request. I'll just baseline, unless the AFR moves on me, and we have to tweak the VE tables
Old Dec 28, 2016 | 10:27 AM
  #534
drain89's Avatar
Darth, what are your plans for the short block? Eventual upgrades?
Old Dec 28, 2016 | 12:37 PM
  #535
Darth_V8r's Avatar
Moderator
No, I'm planning it to last. If I do end up losing the short block, I'll grab a LS2 bottom end and bolt everything right back up. But every time I've had the heads off, it's been fine on the inside.
Old Dec 28, 2016 | 01:44 PM
  #536
A.R. Shale Targa's Avatar
No, I'm planning it to last. If I do end up losing the short block, I'll grab a LS3 bottom end and bolt everything right back up. But every time I've had the heads off, it's been fine on the inside.
Fixed for you.
Old Dec 28, 2016 | 03:24 PM
  #537
Darth_V8r's Avatar
Moderator
Originally Posted by A.R. Shale Targa
Fixed for you.
That's a good fix. I'll accept that one!
Old Dec 28, 2016 | 07:54 PM
  #538
Mike Morris's Avatar
Sounds great
LS2 bottom end is what I am doing. But with cubes...
Old Jan 3, 2017 | 09:09 PM
  #539
So darth, what's happening with this car with the new year rolled in now. Had to chance to get the new msd numbers yet?
Old Jan 3, 2017 | 10:14 PM
  #540
Darth_V8r's Avatar
Moderator
Been playing tag with the dyno. Thought I was in Friday, but didn't work out cause their morning tune ran long and afternoon guy showed up. Same today. I'll keep trying.
They offered to get it done if I leave it but it's my DD so I can't.
