MMS 220 Build for "Ghost Hawk"
Old Dec 18, 2016 | 08:06 PM
  #481
Darth_V8r's Avatar
Moderator
Default New Results Are In!!!!!
Hello, Tech. I posted here for unity with the build thread and in the dyno section for relevance.
To cut right to the chase, I got new numbers and I'm super stoked!
510@6500 and 448@5500. This was done on a different dyno in order to dial in some low rpm and part throttle stuff I was struggling with on the street. I'll go back to the other dyno to get a more direct comparison on the previous dyno I ran on after all the current testing (and tuning) is complete. Regarding the different dyno's, I asked the operator how his dyno compared to the other one I previously tested on and he said they were typically within a percent of one another and that on any given day, one might be 2-3 HP higher or lower than the other. Guess we will see when the smoke clears. Overall, he was very impressed with the quality and attention to detail of my build, especially compared to the POS hot rods he typically sees where people think they can dump $300 into a car and get 400 HP. He blames hot rod magazines for that, which I thought was pretty funny.
So the dyno operator is extremely ADD and he likes to be left alone while tuning and doing pulls, so I was relegated to a waiting area while he tuned. After the first pull he immediately enters the waiting area where I'm anxiously sitting and asks me to confirm the displacement of the engine. I tell him once again its a 346 and he seems very surprised sharing with me the first run/baseline was already 501/441 (which was close to where I was hoping it would be!), and then he shares with me the previous best 346 on his dyno NA was 470. So, he continues to work the tune over the next few hours, and we end up at final figures of 510/448 which is obviously awesome! Even some other guys in the shop and office came up and asked about the build during all this, so word had already spread. When it's done, the first thing he says to me is "You must have the best cylinder heads on the planet! I've never seen anything like this, and if I hadn't ran the dyno myself I would be calling BS".
Afterwards, we chatted for a while, and we started talking some of the behavior on the dyno. First, it ended up making the best power at 23 degrees timing, which just floored me, but it was true. At 26 degrees, it didn't knock, but it pulled 501-504 on consecutive pulls. I wish we had 93 instead of 91, because a bit more timing and a bit better fuel might have come in even higher. He said that the 5500 peak torque suggests very strongly that this thing wants to make peak power higher. But during the pull, you can hear the tone change around 6300 (video attached so you can hear it plain as day), and that change carries to 7K, where he stopped the pull, because it wasn't making more power. And you can see on the attached graph, that it just flatlines at 6300-7K as well. So, he tells me the intake is holding the motor back, to which I started laughing. I told him I just had a hard time thinking of a Mamo ported fast 102 holding an LS1 back. He then says, he's in uncharted territory with this motor as well, since it beat the previous best on his dyno by 40 HP!. He says that it feels almost like some weird harmonics in the intake where the heads are trying to draw in more air and it's just not available. He then says, he thinks the engine needs a bigger plenum intake with shorter runners. Which points straight to the MSD airforce. Or sheet metal, which I don't want. I discussed this with Tony Mamo later that day and we had (in the past), already batted around the idea of trying one of his ported MSD's on my motor knowing going in we are going to trade low/midrange torque for upper RPM power, based on some of the other testing Tony has done. I REALLY want to see what the full horsepower potential of this combination is so I have already given Tony a deposit to get one of his ported MSD intakes in the works which should be an awesome test - and back to back with no other mods. If the MSD does what I HOPE it does, I'll use the fast for a truck build up in my suburban.
Comparing this run to the previous run at 496, there are some interesting changes, which do point to potentially reaching the ceiling of the fast 102 at the high end - not entirely sure on this, since bigger cube motors do fine on it, but it may be RPM related. Here is sort of a chart to try to help summarize the differences between the pull:
HP............................496................. ..............510
RPM........................6800................... .........6500 (indicates intake potentially not keeping up)
TQ............................431................. ..............448
RPM........................5100................... ..........5500 (indicates power band shifted higher in RPM)
Cam.....................hydraulic................. ........solid
Duration...............227/235......................232/240 (hydraulic equivalent)
LSA/Adv................112+3.......................... 112.5+2
Rear Axle..............stock........................... ..fabbed 9"
Gear.......................3.42................... ...........4.11
As I understand it, when you increase gear, you "consume" HP to gain torque. Add to that the weight of the rotating parts of the rear, and I figure there must have been at least 20 HP in driveline losses due to the upgrades that were made in response to all that DAMAGE. I blame Mamo torque! I did what I could to minimize those losses, but it needed the heavier hardware, and the car has responded quite well to the gear, enabling me to run 28" tires - to which the car has also responded quite well.
So, next steps: I'm going to try a Mamo ported MSD. Based on the torque peaking higher and the HP peaking lower, I do agree that the shorter runners of the MSD will help the top end of the combination carry power better. We'll do the swap and go back to the same dyno for a direct comparison between the two intakes, which will be the first test of Tony's ported cathedral MSD on a 346 cube engine. Once that is done, I'll go back to the dyno I pulled the 496 on many months ago for a direct comparison of before and after. I also need more injector. The 39 pound deatshworks are at 92% duty cycle. I have a set of 42 pound FIC that will go on. These have the EV14 spray pattern, which will do much better at lower flow vs the stream of **** the deatshworks make, but I will change the injectors after the intake swap to eliminate any variables that could affect the intake manifold test
At this point, I feel we could be close to finding out how much can truly be done with a street 346 with some of the best parts on the market currently available!
Stay tuned!
File Type: mov
Old Dec 18, 2016 | 08:27 PM
  #482
DavidBoren's Avatar
No way! That is ******* stellar, man. Great results, so far. Definitely interested in the MSD results. Keep it up. A 500rwhp naturally aspirated 346 is no joke. Congrats.
Old Dec 18, 2016 | 08:31 PM
  #483
98_WS6_M6's Avatar
Man looks awesome Jake. Congrats buddy. Must feel great to get it all lined out too. Can't believe you already ordered the new intake! But I would have too so I shouldn't be too surprised lol. Such a great job for this build. And the updated numbers are amazing. Especially with the addition of the 9" plus the 4.11 gear ratio as well. So much attention to detail in this build you deserve it. Bet you're pretty excited with it overall. Moving on to a suburban build now lol. Any plans on going to the track yet or are you going to wait for the MSD first?
Old Dec 18, 2016 | 08:43 PM
  #484
SoFla01SSLookinstok's Avatar
Wow! Great job man. Makes more torque than my 383.
Old Dec 18, 2016 | 08:49 PM
  #485
Darth_V8r's Avatar
Moderator
Thanks guys! You have no idea how stoked I was! My poor wife!
@SoFla I think that has as much to do with the RPM it peaked at as anything else. Look at the graph, and it peaked lower at 5000, dipped and surged, and then carried. I really didn't expect any more torque than 435, so I was caught off guard to say the least.
Old Dec 18, 2016 | 08:51 PM
  #486
Darth_V8r's Avatar
Moderator
I want to see which intake is more better. That'll be the combo I take to the track. Coming from you, that means a lot. Your build is going to be a very interesting comparison
  #487
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Jake
Outstanding,
Congratulations on a job
Very Well Done!
Old Dec 18, 2016 | 09:13 PM
  #488
conan's Avatar
Nice work cracking 500 with the little old 346ci, congrats.
Old Dec 18, 2016 | 09:17 PM
  #489
Firebirdmuscle's Avatar
Awesome job darth. Those are some serious numbers from a 346. I hope my mamo build gets close to that. Awesome job on everything. Time to get some track time on her now.
Old Dec 18, 2016 | 10:58 PM
  #490
Darth_V8r's Avatar
Moderator
Originally Posted by NAVYBLUE210
Jake
Outstanding,
Very Well Done!
Thanks guys! Track after MSD testing. I want it to be at its best when I go to the track so I don't have a bunch of questions or second thoughts. I don't think it'll take too long, honestly. If Tony ends up delayed or something and I get a day where nobody's home I might run it. But I doubt that. I've never had Tony take forever on anything.
Old Dec 19, 2016 | 02:04 AM
  #491
sxc Z28's Avatar
Good job sir! The 510rwhp is very nice but I must admit the 448rwtq on 346ci is what wont leave my mind! Those solid roller cams sure are the way to go with a top tier cylinder head like Mamo.
That 91octane tho.
Old Dec 19, 2016 | 07:15 AM
  #492
Darth_V8r's Avatar
Moderator
That 91octane tho.
That's what got me too. I expected more like 430, and a 500 peak, but at 7k. I'm now to the point that I don't think you can beat top shelf heads with LLSR. Navyblue just put up monster numbers on a Mamo/LLSR combo as well.
98_WS_M6 will be a really interesting comparison cause his top end is similar (except hydraulic) but his cam is virtually identical. I think he's 234/238?
Old Dec 19, 2016 | 02:48 PM
  #493
jhshnh's Avatar
Dial in the pinion angle, lca angles, and shock settings and this is a 10 second car all day long.
Old Dec 19, 2016 | 04:31 PM
  #494
98_WS6_M6's Avatar
Pretty close. 235/238 620/615 on a 114
Agreed buddy! I'm curious how light he got the car now too.
Old Dec 19, 2016 | 05:58 PM
  #495
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Guys,
In the event you dont or didn't see my response in the "Dyno Results" section I thought I should post a copy of it here as well!
Just wanted to throw my hat in the ring here and also extend Jacob a big congrats on the results. He is another guy that has sweat all the details of his build. This guy invests a tremendous amount of time thinking about and wrenching on his car and the results are the sweet victory of that effort (for the folks who may have missed his detailed beyond detailed build thread be sure to check it out).
And not to mention he is a genuine good guy who helps out the community as well with all the info he freely shares
Regarding the manifold test I expect the results to mirror the test I conducted awhile back on the engine dyno with a 416.....basically giving up a good bit of lower/midrange torque for an inprovement in peak power and the engines ability to hang onto it.
The car may even fell a tad slower driving around town but assuming the top of the curve does come around (like my 416 example), and your willing to sidestep the clutch around 5500 and shift in the 73-7400 range, the car will be brutally fast keeping the RPM up there in it's new "sweet spot" (It will be a more "peaky" power curve with this manifold choice)
Should make for a wicked sounding in car video.....hint hint......LOL
Here is a very informative thread I posted a ways back about my ported MSD vs my ported FAST.....read it if you haven't seen it as this intake isn't for everyone....you need a well thought out and optimal valvetrain (with perfect valve control), especially in a 346 which will want and need to rev high to take full advantage of its attributes.
https://ls1tech.com/forums/generatio...orted-msd.html
Cheers,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Dec 20, 2016 | 12:45 AM
  #496
corysmach1's Avatar
Congrats Jake! I bet the car feels great I can't wait to see what it runs. Have you weighed the car yet?
Old Dec 20, 2016 | 07:03 AM
  #497
Darth_V8r's Avatar
Moderator
I do need to weigh it. If I had to guess I'd say around 150 pounds lighter. Mostly off the front. There's more I could drop pretty easily I've just been focused on getting chassis dialed in and running well.
Old Dec 20, 2016 | 08:04 AM
  #498
corysmach1's Avatar
Good deal buddy....Keep us posted.
Old Dec 20, 2016 | 02:24 PM
  #499
jhshnh's Avatar
10 second car all day long. He's got the suspension and rear end for it. Can't wait to see the track times.
Old Dec 20, 2016 | 05:12 PM
  #500
NHRAFORMULA00's Avatar
Congrats too the over 500 club. Do you have a guess at race weight?? We dynoed 522 with my sons first 346 before he broke a ring. replaced it with a 6.0 block and it dynoed the same HP but picked up almost 40 ft lbs of tq.
