Best heads for my car?
Then, you didn't tell us what your car is. We could assume it is an f-body but you didn't really say.
Do you want to buy heads or would you like to end what you have out for porting?
4.10 gears should be done FIRST.
Then later when you want to try and do the heads thing understand $1000 wont do it once you consider all the other stuff needed. I would budget $1000 for fluids, surprises, and tuning separate from whatever you spend on heads and fresh springs.
https://texas-speed.com/p-4345-prc-s...-outright.aspx
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
