Should I swap cams?
Would I benefit from going to a bigger cam like a 228r or Torquer V2 provided I get long tubes? How much power and torque do you really loose from stepping up to something in the high 220/ low 230 range. With my 4.10 gears, I believe I can benefit from a cam swap but wanted to get more input.
I have Comp 921 springs and titanium retainers etc.. so swapping the cam itself would be all I need most likely.
With exhaust manifolds the mph I think looks good, and the talk of swapping to such a big duration in the same breath as complaining about lack of lowend tells me you have a lot to learn before you should be inside the engine.
I would get a set of headers first. You aren't doing that cam any favors with the factory manifolds.
I think due to the gears, im get over 3k rpm quickly when doing a pull which would mean that something with midrange and high end power would be much better for my application.
