Comp Ultra-gold rocker arm failure
Guys,
Figured I'd throw this out to get your opinions here.
370" LQ4 based engine
Edelbrock E-cnc 215 heads
Speed inc TU1.5 cam (.571/.571, 228/228, 112LSA)
BTR .660" platinum springs (steel retainers), 155lb on seat ~380lb @.571"
5/16" comp push rods
1.72 Comp Ultra-gold rockers (pedestal mount)
Billet wheel PT-7675
That's all the important stuff I think. One of the rockers failed a couple of days ago. As you can see in the pic the tail broke right off. This isn't a new build, there are a few thousand miles at least and I've revved this thing to 7k more times than I can count.
Springs appear to be fine. I can get the valve off the seat pushing on it, super stiff, feels the same as the rest, as empirical a test as that is lol. Swapped a good rocker in place of it and compression is fine, same as the rest. Spark plug is fine, push rod is straight still as well.
What do you think? Isolated incident or should I be looking at replacing these with a different type/brand? I've always had great luck with comp cams stuff.
![](http://i58.tinypic.com/2isw186.jpg)
Everything else may be fine. I've seen failures with every rocker but Yella Terra seems to be the go-to in the mid-priced range roller. Have you checked all of your push rod lengths and what lifter do you use?
All of the push rods look fine, aside from the one that bit the end off that rocker, it's a little scuffed up but still straight. They're 7.400" long. I'm not positive what lifters are in it, I didn't build this engine, a shop did. I do remember them saying they were comp as well, they still use the stock buckets.
Super Hulk Smash
Aluminum fatigues over time. Depending on how many miles/heat cycles were on the rockers, it could just be age.
Or, it could be an out-of-control valvetrain that beat up the rockers over time as the lifter lofted and the pushrod cup of the rocker took the brunt of the force. Those springs are probably too light for the weight of the rockers. Tooley sells a max pressure version with a 450lbs open pressure to control the aluminum roller rockers.
That sucks.....I've seen hs rockers fail. I attributed that to the springs because i have run hs rockers for probably near 40k miles......and i spin to 7k to. I have run stock ls6 springs with them and psi beehive springs. The ones i seen fail was on a double spring. To me if you gonna improve these engines you don't back up to a double spring. Use beehives or better yet conical and ti retainers.
I don't think the springs being too spring here caused the failure Hio, the springs may be heavier than a beehive but as long as the keep the valvetrain in control there shouldn't be issues. They have roughly the same open pressure as a psi but more seat preesure which should help control quite a bit.
I'm inclined to go with the pushrod pole vaulting at 7k and aggressive cam lobe beating up the rockers
Moderator
Received 1,838 Likes
I don't think the springs being too spring here caused the failure Hio, the springs may be heavier than a beehive but as long as the keep the valvetrain in control there shouldn't be issues. They have roughly the same open pressure as a psi but more seat preesure which should help control quite a bit. I'm inclined to go with the pushrod pole vaulting at 7k and aggressive cam lobe beating up the rockers
Makes you glad you went larger PR doesn't it?
The rating on op's springs are similar to my psi springs.
Super Hulk Smash
I don't know what the engine was exposed to, how well the Comp rockers are made, or anything. But he doesn't have stock cam lobes. He has pushrods that look like noodles on a spintron. He has a spring not designed for the weight of the rocker on an aftermarket lobe. There's lots of possible issues.
I would move to an 11/32 pushrod and stock rockers with BTR upgraded trunions on the rebuild.
Could just be a defective rocker. Doubt a push rod would have anything to do with that. How's the piston/valve clearance? How far from coil bind are the springs set up to?
But IMO I suspect the rocker had too many voids/casting issues in the alum and let go. Maybe Comp can look them over for you.
Also, I had to grind the hell out of my valve covers to get enough clearance for these. Everything else remained the same, wipe pattern is good, no shimming req'd and the same pushrod length still works.
![](http://i61.tinypic.com/jfdddu.jpg)
Moderator
Regarding the covers, I used a really thick gasket to gain space. FWIW
The rocker that broke was on an exhaust valve. Funny thing is that it let go putting down the road in front of my house. I figured for sure it had dropped a valve by all that banging and clanging that started, pretty scary.
Thanks for the info about the thicker gaskets, didn't know they were out there at the time.
