Install head bolts dry?
Old Nov 25, 2002 | 04:05 AM
C_Williams's Avatar
Default Install head bolts dry?
Any lube used on the head bolts or are they recommended to be installed and torqued dry?
Thanks
Old Nov 25, 2002 | 04:49 AM
Tin Indian's Avatar
Default Re: Install head bolts dry?
The new TTY head bolts have an anti-sieze compound on the threads.
Many engine builders will tell you to lightly lubricate the “face” of the bolt head that comes into contact with the cylinder head with ARP ‘Lubro-Moly’ or equivalent. Do not put lube on any of the bolt threads. Lubing only the bolt face will make for more accurate torque angle readings, and will let the bolts stretch evenly.
Hope this helps...
Ron,
Old Nov 25, 2002 | 05:40 AM
LS1derfull's Avatar
Factory block and head bolts have a peculiar coarse thread to them , they come out somewhat hard . This requires extra care cleaning block threads before reassembly, or torque readings will be inaccurate. It is for this reason that i use and reccomend head studs.
Old Nov 25, 2002 | 11:07 AM
DrkPhx's Avatar
I put a very light coating of fresh engine oil on all of the head bolts. No problems yet.
Old Nov 25, 2002 | 05:28 PM
SixPak's Avatar
I've always run a tap coated with some grease in and out of any holes on the block to insure easy assembly, and also to get any crud out of the hole that mighta snuck in when I wasn't lookin. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 25, 2002 | 05:43 PM
jmX's Avatar
jmX
For the stock TTY style head bolts its not really nessisary, but for ARP head bolts you will need to lube the bolts and the underside of the head.
With a TTY bolt, lubing the threads is much less of an important thing.
With both types of bolts, clean threads are a good thing to have.
Old Nov 26, 2002 | 11:18 PM
2001CamaroGuy's Avatar
what is the thread of the 11 mm bolts? I am about to do a head swap (puting studs in) but I don't know what the thread is (1.25, 1.5, 1.75, etc....)
Old Nov 26, 2002 | 11:22 PM
jmX's Avatar
jmX
I'm not sure exactly what it is. I need to get a thread guage.
Why do you ask?
Old Nov 27, 2002 | 01:51 AM
CRASH 02's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2001CamaroGuy:
<strong>what is the thread of the 11 mm bolts? I am about to do a head swap (puting studs in) but I don't know what the thread is (1.25, 1.5, 1.75, etc....)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's none of them. It is some wierd size. What we did when we did a H/C job was we ground down the side of one of the old bolts. Then we put a little grease on it and ran it in and out a few times. Did a good job for us since we didn't have the correct tool.
Old Nov 27, 2002 | 09:50 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jmX:
<strong>I'm not sure exactly what it is. I need to get a thread guage.
Why do you ask?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I need to know so I can go order one.
Old Jan 16, 2003 | 01:07 AM
Randy WS6's Avatar
Me to, I would like to use a tap. it would clean up and fix any bad theads
Old Jan 16, 2003 | 01:52 AM
2xLS1's Avatar
Thread size is M11x2.0
Old Jan 16, 2003 | 05:02 PM
CrankinYankee's Avatar
C5 CORVETTE check your hotmail, I have a question.
