Pistons hit valves
Sorry, you did say a couple of months. You'll still have to hurry to make it!
if you plan on running the same cam and youre having ptv clearance problems. you will need to either fly cut or buy aftermarket pistons
Congrats on the sobriety, drinking and driving is bad enough, in an LS1 its a signed title to death. I wish many of us didn't know this as well as we do.
That said, if you drink, at least take an Uber or something, please, and congrats on sobriety keep it up.
The repair.. You have ceramic-alloy pistons that will not be damaged by a little valve slap. Your 7.4" (if I recall) push rods will bend six ways to sunday (and cause serious problems) before your pistons gets a sense any action is occurring.
Is your objective to have a very fast car, or to have a car that's put together and runs? Also, don't reuse stretching bolts if possible, use quality new gaskets, keep it clean, use proper methods, etc. That's important.
PM me if you need anything else, but school up and post pics of those pistons and do it ahead of time b/c u may well have finishing issues. Best luck
You might want to just leave the old cam in there until you get to SAM. Once the cam is in, you're ging to need a tune too which is another expense. Houston has some really good tuners here, and Pat G is just a couple hours away in Victoria.
But if you decide to swap in the cam now, you can probably pickup a cheap flycutting tool that will cut the releifs in the pistons. That way you don't have to buy new pistons, which usually require a professional hone job. If you're going to start SAM, you may want to build something there when you can machine it and do it right, and have some guidance from some really knowledgeable people.
The guides in these heads usually don't wear too bad, but if you replace them, you're going to need a valvejob too. Again, something you would want to wait until you get to SAM to do yourself with some of the valvejob cutters they use.
Congrats on the two years sober BTW. You should be proud of that!
Honestly, you will most likely be able to run the stock pistons regardless of the valves hitting them. I've seen factory pistons with some deep gouges from contact run without issue, and I mean contact to the point we thought the pistons were flycut .060". Since you didn't notice the marks until you cleaned the tops, I'm assuming they aren't anything much more than little dings in the surface of the piston.
