Effect on different LSA and ADV. ground into the cam?
114 would peak higher than a 112 given the sam specs,and advance ground into them?
So assuming u have 2 cams:
224-224 546-546 114 +4
224-224 546-546 112 +4
Where do u think these cam would PEAK?
Now what if u grind the 112 with +2 advance?
Where would that peak?
JS
I think in some cases the 108icl is stuff is too low because you end up making sick midrange but the cars peak at 6200.
Tighter lsa (i.e. lower number) equals a powerband which comes on later but will make more peak power and torque and often times make more power under the curve.
Most people get confused and site the lower lsa as the reason a cam peaks sooner but it is really the earlier intake closing point that makes the power come on sooner and fall off sooner.
<strong> Most people get confused and site the lower lsa as the reason a cam peaks sooner but it is really the earlier intake closing point that makes the power come on sooner and fall off sooner. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Exactly!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Looks like a 224-224 546-546 112+2 would be good for what I wanna do?I think this will get me the 6100 to 6200 PEAK I'm looking for and make KILLER TQ in the area under the curve and keep it broad to 5000...
Now should I run a XE-R lobe or a XE lobe?I know if I do the XE-R I'll need to discard the 02 LS6 springs for the 918,but what about the XE lobe?Could I run this cam spec (224-546) with the 02 LS6ers and if I can how much would I be given up as far as HP/TQ?
JS
<small>[ March 16, 2003, 07:38 PM: Message edited by: JS ]</small>
Jason
I guess u feel the XE-R isnt needed then?This would be a custom grind done by Comp.My LS6 heads are STOCK,no porting whatsoever.
So where do u think this cam will peak?
Jason I think your right,I'm gonna run either the Nextek
or the 918 with Ti retainer just to be safe.
Calling Comp tomorrow...
JS
<small>[ March 16, 2003, 07:50 PM: Message edited by: JS ]</small>
How much more lift do u think I should run with the stock 02 LS6 heads and lighter valves?I would think 546 should me fine especailly for a 6400 max shift point?
Looks like u are pushing me into the TR cam <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I ran it once,its an awesome cam but I didnt think losing .15 of lift would really hurt me that much?
I'm gonna call COMP in the morning...
Who knows I might call Paul at TR too.
Thanks for the help..
JS
<small>[ March 16, 2003, 08:29 PM: Message edited by: JS ]</small>
