Changing Valve Springs
I also used the TDC method for the valves. Have a look on LS1Howto.comI think access is a problem with some tools.
Tom.
daniel
daniel
daniel
when you take the guage off and plug the air hose onto it tube you need to take the schrader valve out of the threaded end so that air flows free and will keep the cylinder full. Its pretty easy. hardest part is getting the hose in in cylinder #6 and #8. since the spark plug hole faces towards the firewall. Hope that helps.
As far as the original topic....The Larry tool is by far the easiest I have ever used.
