Input on Supporting mods for cam
Old Oct 8, 2015 | 11:20 AM
boost21's Avatar
Default Input on Supporting mods for cam
Hey guys I am picking up a custom grind cam from a co worker and plan on installing it this winter. I know I will need pushrods and valve springs but what else? I was thinking of home porting a set of 243 heads for more flow and more than likely a converter.
Specs on cam (very similar to G5X2)
232/240 duration @ .050 .593/.609 lift cam 114LSA
Current engine mods
LS6 intake
1 7/8" Kooks long tubes
Texas speed 3" true dual exhaust
Chris 101 Ram air
Tune
Was thinking ported 243's a 3,000-3500 stall, new pushrods (Comp 7.4s seem popular?) Springs and a retune. Any other things you guys would recommend? I know its kinda a large cam so I want to make sure drivability does not suffer too bad.
Old Oct 8, 2015 | 11:32 AM
KCS's Avatar
KCS
Moderator
A 4" crank, 6.125" rods, and forged pistons.
Old Oct 8, 2015 | 12:35 PM
Jtm2085's Avatar
Think about oil pump and timing chain...
Old Oct 8, 2015 | 01:10 PM
boost21's Avatar
You think stock cubes arent enough? Seems like a lot run the G5-X2 on stock rotating without issue?
I had thought about a ported oil pump and new chain but have been undecided on it. My old Z had a stock pump with a SI5 (Duration @.050 is 231/237, LIft is .589/.595 112 LSA) with good pressure. A chain would be an easy swap as the front cover would be already off for the install.
Old Oct 8, 2015 | 02:01 PM
Darth_V8r's Avatar
Moderator
While you're having the 243's ported, have them milled. Compression helps drive ability.
Don't assume a pushrod length. Get an adjustable and measure. It'll delay assembly by a week but you'll be better off
Old Oct 8, 2015 | 02:25 PM
DavidBoren's Avatar
Definitely measure for pushrods. And I would advise you have the 243's cnc ported for consistency, rather than taking a dremel to them in the garage.
Old Oct 15, 2015 | 03:40 PM
thompson's Avatar
With your plans to remove the cylinder heads I would go ahead and replace the lifters. Better to do it now while the cylinder heads are off rather than not do it and have to do it later. Also while your doing the camshaft swap go ahead and replace the oil pump and consider swapping the stock chain to something like an LS2 replacement. This will be relatively inexpensive and just add to the reliability of your build.
Thanks
Aaron @ Thompson Motorsports
Old Oct 15, 2015 | 05:36 PM
squalor's Avatar
You'll need bigger injectors too but don't put them on until your in the tuners parking lot.
Old Oct 15, 2015 | 09:40 PM
TXZ28LS1's Avatar
I run TSP 233/239 on 112, with 4000 stall, and livernois LS6 heads..
This setup drives very well.. shouldnt have any problems.
Old Oct 16, 2015 | 10:34 AM
LivernoisMotorsports's Avatar
Current engine mods
LS6 intake
Chris 101 Ram air
Tune
Hello, we have everything you need to complete your install on the shelf.
Thanks for the shout out"TXZ28LS1"
You need a set of springs anyways so it doesn't make much sense to consider doing a home port job.
Send us your castings and valves, we will turn them into a set of our stage 2 heads and you will not be disappointed.
This service starts@$1299.99 and includes the all U.S. made spring, seal, i.d. locator, Ti retainers and lox package along with the CNC porting and CNC V/J
-head gaskets
-head bolts
-set of our rocker braces
-timing set
-oil pump?
-new o.e. rockers(condition of old ones dependent)
-LS2/7 lifters
http://www.livernoismotorsports.com/...der-Heads.html
