402CI lq9 machining issues
Old Oct 11, 2015 | 03:59 AM
S_M_I_D_D_Y's Avatar
Default 402CI lq9 machining issues
Hi guys. ive got a built engine consisting of:
lq9 block
cp Bullet flat top pistons
lunati rods & crank
engine is twin turbo, making around 1200rwhp @ 24psi boost
around 3-5000 miles street driving and a few race weekends. (no odometer)
anyways. i have had a injector go bad, lifting and torching a head in the process. when i lifted the heads i found that all 8 holes the hone marks were worn off the bores at top and bottom sides of each cylinder, sides look perfect. this engine has no blow by and ran 100% perfect untill the injector issue. have included a couple of pics, each bore is the same. any score marks you see look much worse than they are. you cannot catch a finger nail in them. also included my measurements of the bores taken with a inside micrometer NOT a bore guage.
Old Oct 11, 2015 | 08:37 AM
KCS's Avatar
KCS
Moderator
Except for the third pic, it looks like normal skirt wear. Pretty typical in big power adder application like yours.
Old Oct 12, 2015 | 01:13 AM
thanks mate. what about the deck heights. its in the measurements pit but ill add the measurements here for the bank im worried about:
1. -0.009 3. -0.004 5. 0.000 7. +0.003
this IS the bank which had 2 lean injectors, cyl 1 15% blockage torched the head and cyl 5 was also 10% blocked and the gasket blew out here also but no head damage
Ideas?
Old Oct 12, 2015 | 05:37 AM
KCS's Avatar
KCS
Moderator
Ideas?
It depends how you measured. Did you measure the pison rock or just take a measurement from somewhere in the middle of the piston?
Old Oct 12, 2015 | 10:25 AM
Measured rock with depth mic, and straight edge with a feeler Guage on the center of piston. Both worked out about same results
Old Oct 12, 2015 | 08:43 PM
S10xGN's Avatar
FWIW, my pistons were "out of the block" by different amounts:
1: +0.0035 / 2: +0.0007
3: +0.0025 / 4: +0.0010
5: +0.0020 / 6: +0.0025
7: +0.0045 / 8: +0.0035
On a fresh build, too. The right bank has a "lean" to it, but the left bank seems just...uneven.
Old Oct 15, 2015 | 09:32 PM
speedtigger's Avatar
Old School Heavy
Were you taking these measurements just above the wrist pin? If not, piston rock in the bore will lie to you.
Old Oct 16, 2015 | 08:09 PM
S10xGN's Avatar
Those numbers came solely from "piston rock". At TDC, I loaded one side of the piston, took a deck (dial) indicator measurement, repeated this on the opposite side of the piston, and averaged the two against the deck "0". I prolly should have used a mic to measure from the wrist pin hole to the deck, but aren't these, in fact, "real world" numbers?
