HP vs TQ Theory
Rear wheel torque.....in 1st gear (2.66)
5000 = 2940.6
5500 = 2974.4
6000 = 2906.8
6500 = 2805.4
7000 = 2602.6
7100 = 2561.6
7200 = 2475.6
7300 = 2399.8
7400 = 2350.6
7500 = 2298.4
7600 = 2163.2
7700 = 2028.0
Rear wheel torque.....in 2nd gear (1.78)
4800 = 2574.7
4900 = 2565.2
5000 = 2557.8
5100 = 2562.5
5200 = 2573.7
5300 = 2579.0
5400 = 2583.5
5500 = 2587.2
6000 = 2528.4
6500 = 2440.2
7000 = 2263.8
7100 = 2211.9
7200 = 2158.1
7300 = 2105.8
7400 = 2052.4
7500 = 1999.2
7600 = 1881.6
7700 = 1764.0
So, knowing my 33% drop from 1st to 2nd....
7500 = 5019
7600 = 5086
7700 = 5153
So....your 7300rpm = 4885rpm, your first choice isn't bad.
There's also more to the average power calc. But it's a little controversial by some.
I was shown this "other" method by a current IHRA prostock racers. And it has proven to pick my combo up a little more (because of shift points). It's a calc that changes these averages a little.
And I prefer this "other" calc because it uses hp & tq !!
The goal is to shift at the RPM your HP on the right side of the curve (as the engine starts rolling off its power peak) meets the left side of the curve at the exact same HP figure on the way up. Shift too early and you fall way down on the next gear....shift too late and you would have the felt the car nose over a little as the power was lower past peak then where it shifted to. For example.....en engine makes say 500 HP peak.....if you shifted at 460 on the right side of the curve and the gear split put you back at 460 on the left side of the curve you nailed the optimal shiftpoint. If you shifted early at say 470 on the right side you may fall all the way back to 440 on the left and have to climb back up the curve....the trick is to ride the crest of the power curve. Shift late at say 450 on the right side of the curve and you would have slowed down some by not shifting soon enough even though it might hit 470 now on the way up (you would have felt the car lay down a little briefly).....its still best to try and split it perfectly so you feel the most constant rush of power. In manuals with varying gear spread transmissions that might mean a slightly different shiftpoint for each gear if your really splitting hairs and trying to extract the most from the combo.
Do this every gear down the 1320 and that means you maximized the most horsepower during the run which will net you your fastest trap speed and lowest ET if your able to effectively apply all that power to the ground (another topic entirely).
In the scenario LSHolic shows us I would say Darth's 7300 guess was right on or close but it depends on gear spread and converter efficiency as well.....its easy in a manual car....you just split the numbers....not many variables. If somehow shifting below 7K in that situation caused the vehicle in question to go faster, something is wrong with the car as it's accelerating down the track (something that's not being seen on the dyno in a static state test....such as not enough fuel pump to overcome the G-force).
LSHolic....what is your reasoning on why modified diesel applications with gobs of torque aren't running insane trap speeds if max torque were so important to acceleration.....you cant causally ignore that fact or the fact a motorcycle produces incredible results because it produces so many HP per liter (and minimal torque figures) and as a result flies down the racetrack due to its insane power to weight ratio.
I say it again.....Power to weight ratio is really the thing to leave this thread with if your concerned with improving your acceleration.....you can make more power or lose some weight.....or BOTH.....all of which help to achieve the nirvana/drug we refer to as acceleration.
Hello.....my name is Tony ("Hi Tony")......Im addicted to a drug called acceleration!!
-Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
I still think it is calculating too much torque (blue line) on the low end, but it is pretty close to my last dyno pull from about 3600 to 7000. Below 3600 really doesn't matter anyway. HP (green line) is very close.
Again, what I'm seeing in the model is that the increase in g-forces exceeds the increased airflow at peak power. If I could find a way to express it mathematically, it would be something like:
HP = F(rpm) (F meaning function)
dHP = DAirFlow/drpm + DPistonAccel/drpm
Peak HP occurs at RPM where Dairflow/drpm + DPistonAccel/drm = 0
http://www.metaris.com/hp-relations.php
TQ is falling off pretty fast. The only reason HP continues to climb is the RPM increase.
Here are the numbers for the curves:
RPM.....TQ........HP
400....173.1....13.2
800....244.4....37.2
1200..299.6....68.4
1600..333.9....101.7
2000..357.9....136.3
2400..371.5....169.8
2800..383.8....204.6
3200..400.9....244.2
3600..417.2....286.0
4000..429.7....327.2
4400..439.0....367.7
4800..444.5....406.2
5200..437.7....433
5252..435.3....435.3
5600..420.0....447.9
6000..401.0....458.1
6400..381.9....465.3
6800..361.3....467.8
7200..338.9....464.6
7600..317.2....459.0 Manually extrapolated
8000..295.4....450.0 Manually extrapolated
Svede, does cleaning up the graph and posting the calcs help? If something is still messed up, tell me what RPM range.
Basically, compared to the actual dyno pull, the torque curve is flatter on the dyno. 400 pounds from 3800 to 6100, and it peaks at 417 vs 444. Nailed the HP number, though. 467 calculated vs 474 dyno.
Sorry for it being sideways. Loaded off my phone.
But, agree or disagree....rear wheel torque is what moves the car down the track. Thus is a very more accurate way to achieve proper shift points.
Personally, what's happens at the crank takes a back seat to what's happening at the wheels.
If it wasn't about tq multiplication and hp was the golden ticket, then rpm wouldn't matter as well as gearing. But...as we all know.....rpm and gearing are arguably more important than any other factor...aside from weight.
Like I said, overlay your g-meter with your torque graph profile....mirror image. And how does the g-meter correlate to the hp graph profile (when hp is peaking the graph is tapering down, just like the rear wheel tq shows you)
It's time to shift when the rear wheel torque in the next gear is greater than the one your leaving. That's what keeps the car pulling and the engine in its max acceleration zone.
And about your diesel example....what your missing is rpm. And I've said all along...I want max torque at the highest rpm my wallet can provide.
Because rpm allows more gear, more gear equals greater rear wheel torque, greater rear wheel torque equals greater acceleration...which means a quicker et.
And to throw the same comparison back at you....since its all about hp. In your world a F1 engine would rule the drag strip with its 800hp and measly 235ftlbs.
Remember Darins statement I quoted ?? Carrying the torque longer is key.
All in all, it's really just semantics.....
Do you notice the gradual leaning out of the engine, and with it the gradual spiking/jagged increase to the graph? This could be a sign of problems. I recommend using smoothing:0 to help diagnosis. Also, richen up the engine to see if the jaggedness goes away. You might also reduce timing.
IMO the engine started getting hot, if this is 93, and the timing was far enough forward to start giving rise to pressure spikes. If the engine has an oem head gasket it should be close to failure if you keep running it like this, otherwise, it will pit the head, deck and piston as high pressure spikes eat away at the chamber and piston. On the other hand it could just be something with the pickup or computer, or even software so that is why I suggest making these small adjustments and observing. It is a coincidence that both the a/f is leaning out and the sudden appearance of the beginnings of a jagged curve.
In simplest terms, 2 horsepower will move an object with a given weight farther than 1 horsepower in the same amount of time. Engines do not just sit at one single number all the time though; so spending the most amount of time, "at the highest torque", "at the highest rpm" is what we are really after. In other words, most horsepower per unit time, or most weight moved the most distance in the shortest time.
2015 Ram hemi HP 395 TQ 410 Weight 5100 lbs per HP: 12.9 1/4:14.1
2000 S2000 HP 240 TQ 153 Weight 2750 lbs per HP: 11.5 1/4: 14.2
http://www.caranddriver.com/reviews/...mi-test-review
http://www.motortrend.com/roadtests/...0/viewall.html
Ditto for no torque Rotary engines like in the RX8....that thing is soooo SLOOOOW for it's HP to weight ratio....
Similar to distance and velocity. Velocity is an instant in time. Distance traveled is velocity integrated over time.
Now, all that said, I'm going back after getting the next round of mods done, probably mid-November, so I'll definitely look into those things while I'm there. I was actually thinking of taking it to a dynapack to bolt the hubs up and take the wheel balance out of the picture anyway. After reading your post, I'm thinking even more so.
I'm definitely going to stay out of the high end now until I get that stuff done. I can always just add fuel or cut timing myself, but I can't measure to know it helped or hurt. Since the jagged stuff doesn't start until 5500, I'm assuming it's not unsafe to drive in the low end and midrange?
For us mere mortals, you know, hydraulic lifters and wet sump oiling, the practical rpm limit is 7k... 7500 in a darn good setup, and 8k if you're Jesus himself.
So, is there any benefits to having more cfm's than necessary for your goals? Say 500rwhp is your goal, and you want to achieve it below 7000rpms. 300cfm can support 500rwhp in a good hydraulic lifter/wet sump application.
AFR 205's are a quality piece, that flow 300cfm. 300cfm can support 370ci of displacement out to 7200rpms, or thereabouts. So, IN THEORY, afr205's SHOULD be capable of producing 500rwhp on a 6.2L before 7k. I haven't seen it happen, but I don't see why it wouldn't.
So, what is the benefits of adding bigger heads, with more cfm potential, when your goals can be met with less?
How important is port velocity vs runner volume?
Or is this an argument of peak power vs average power, and that's probably worthy of its own discussion.
In the name of efficiency, shouldn't you start with by defining your goals. Then select the lowest cfm's that will adequately meet your requirements. Find the smallest heads that flow your desired cfm's. Find the biggest displacement that those heads will support out to the projected redline for your application. Then you select your gears/stall/cam to make it behave how you want.
Or at least that's what makes sense to me. Granted, this assumes that you have an established power goal, and aren't just going for the most you can possibly get.
The most you can possibly get comes in the form of a superdeck block and a 4.5" crank. But that's just not available to us mere mortals, so it might as well not exist.
Early on, I think we all agreed that peak TQ is peak cylinder fill. The problem was what corresponds to peak power?
Not peak airflow
Not peak fuel flow
So, I built a quick and dirty model in excel of the stuff I could think of in the engine that causes internal resistance. In the end, I think it is as "simple" as the work necessary to keep making the engine spin faster exceeds the work extracted by spinning faster. From the rough math, the best I can tell is that the acceleration of the pistons becomes incredibly high and becomes counter-productive.
Horsepower is basically a linear function (y=mx+b). x being its own function complicates it a bit, but y is linear.
the accelerative forces on the pistons are parabolic (y=f(x^2))
What I think I found is that the function is a derivative - in short, very close to what Tony said ("It's dynamic, not static"). You can't look at the point at which HP peaks and see anything, but if you look at the rates of change, it makes very good sense.
I'm going to start a new post to break up the train of thought, because it's going to get messy
Imagine a point just below peak power, say 100-RPM lower, and another point just above peak power, say 100-RPM above peak. Now think of how much energy it takes to get from 100-RPM below peak to peak vs getting from peak to 100-RPM above peak. Intuitively, I think we can all agree "OK, it takes (edit) less energy to get from 6700 to 6800 vs getting from 6800 to 6900" The difference is that going from 6700 to 6800, the work output by the engine is still increasing, but going from 6800 to 6900, the work output of the engine is decreasing.
This is not intended to say anything about where to shift or torque at the wheels. Simply what is happening at the flywheel as an academic exercise
RPM..........6700........diff..........6800....... ..diff.........6900
CFM..........648.3.......+6.6.......654.9......... +6.8......660.7
Energy......933.6.......+9.5.......943.1.........+ 8.4......951.5
G-Forces...2309........+69........2378..........+71. ......2449
Net TQ......366.5......-4.2.........361.3.........-5.6.......355.7
Net HP......467.5......+0.3........467.8.........-0.4.......467.4
So, at peak power, the changes in internal forces that resist increases in speed are equal to the changes in energy input. The amount of energy needed to increase speed equals the resistance to increasing speed, and your net TQ is decreasing at a rate equal to RPM/5252. At its core, it's a derivative from Calculus I. Just got there the hard way.
Last edited by Darth_V8r; Oct 28, 2015 at 05:54 PM. Reason: Correction in second paragraph due to being a moron
The power peaks when the mass of air per unit time peaks. Area under the curve has more to do with calculating how fast a vehicle will be, or how much gear you need to achieve your goal. Peak is simply peak airflow in terms of mass per unit time. We will make the largest amount of power, with the largest mass, of hot-as-possible air, that we can squeeze into the cylinder. The extra heat is energy and more energy will give you more output; the limitation here of course is octane, the unifying factor with all pump gas builds is that the fuel is poor quality, adding an element of surprise and danger to our combinations. A well thought out combination has safety features that allow for fluctuations in octane. And to add a little tid-bit, often you can push an engine "into the danger zone" on a dyno, what starts off as a couple jagged peaks can escalate into a significant spike that will give you a big fat peak number at the expense of your engine's insides.
We do not generally calculate limitation imposed by friction in any engine when consulting power output, because we already know that lighter parts, thinner oil, looser clearances all contribute and then engine has already been built by the time we arrive to this stage (the "lets make a dyno pass" stage) leaving us with only two main adjustments: air and fuel. Adjusting airflow (via boost controller or a throttle plate restriction or cam timing or runner length or other means) is adjusting power output. Peak airflow is peak power, in most if not all cases, unless there is something horribly wrong with the engine the way it was assembled or it was pushed outside of those critical parameters such as valvetrain limitations or piston speed.
Mathematically you may be able to derive such functions by using compressor wheel speed vs engine output (if the engine is on an engine dyno) or including drivetrain losses (if you have a compressor map and air temp, you can calculate mass of air moved via compressor wheel speed, take the difference from what you actually make to find how much you lost to the wheels or flywheel); however, none of that is necessary in a practical application because, again, the engine is already assembled, we have what we have, and now all thats left is to adjust for maximum output (or max economy or whatever the application calls for). I tend to look for max economy AND power, making the thin line a choice between a few extra decimals of safety in my compression ratio vs an extra MPG or two. In either case, if I want more power I just adjust my atmosphere; Everyone stuck in the "atmospheric rut" of using the natural pressure available is missing a significant chunk of useable engine output, in almost every application, regardless of whether we are economy or power focused (turbochargers tend to improve fuel economy).
Tal0n, I very much appreciate the honest feedback. Unfortunately, it's 91 octane. CA / AZ gas sucks. I honestly thought the increased AFR at the end was just letting up on the throttle early. The jagged stuff at the top, he attributed to wheel balance, because he was not getting any KR. I'm actually only running 24 degrees of timing. That's where it made peak power. MLS head gasket. Injectors at ~70% duty cycle at 6800 rpm. ECT's stayed 197 and lower.
It makes sense, I am just a Neanderthal and like to see empirical evidence before subscribing my faith to it.
PS. I think this discussion just found its way back on course to its original intent. Save the shift point discussion for another thread, and let's just keep this thread going about the what's and why's of how peak torque and peak horsepower relate to the mechanicals of a running engine.
