H/C Install and now totally confused.
the reason I'm asking is because my cam numbers were lower than normal also after dyno tuning
I have a 2002 SS with a F13 and I dynoed @ 367rwhp and 351 trq
When you install the cam you have to make sure you line the two dots on the gears dot to dot, 1 tooth off can really mess up your #'s
Thanks,
If you are doing it the mechanical way, you could run into PtoV issues. I am confident that APE installed your cam right, they are very competent there. Now if the dyno calibration is off, I'd love to re-dyno also just for ***** and giggles. But I have a feeling it's calibrated right.
-Steve
-Steve
-Sly
