Ms3, dd ?
Old Nov 5, 2015 | 03:01 PM
IzaguirreZ28's Avatar
Default Ms3, dd ?
Si have decided that im gonna buy a more fuel efficient car and make my 2002 Z28 Camaro a weekend. I want to put MS3 in the car but ive hear that they suck for A4 camaro, how true is that ?
Old Nov 5, 2015 | 03:07 PM
Jake89's Avatar
Any cam can suck for an A4 if not properly tuned and if you don't have the right supporting mods. With that cam you are going to want a decent stall converter. Also, what supporting mods do you have for the cam?
Old Nov 5, 2015 | 03:54 PM
HCI2000SS's Avatar
With a proper tune, mods, gear and stall it could be very drivable and very fast
Old Nov 6, 2015 | 12:50 AM
NLyles's Avatar
I had an MS3 in an auto car with a Yank SS3600 and 3.42's, never had any trouble with it at all. Just gotta have a good tune
Nick
Old Nov 6, 2015 | 01:55 AM
SuperSam's Avatar
Ms3.....4400 stall....3.42....just make sure the tune is one point.
Old Nov 6, 2015 | 07:44 AM
lemons12's Avatar
This.
So many want a max effort cam though and couple it with a 3400 converter.... ls6 intake... And 3600#.
Then wonder why us guys that have a clue walk all over you with a baby 226 cam and similar budget builds.
Max effort cam=max effort everything else.
Old Nov 6, 2015 | 04:33 PM
Fbodyjunkie06's Avatar
For a DD I would want a smaller camshaft than a high 230's low 240's duration grind.
Only if you've previously daily driven a LS engine with a cam of this size would I recommend something that large.
As Lemons said, max effort cam means max effort supporting modifications.
Old Nov 6, 2015 | 05:01 PM
onebadbowtie86's Avatar
I have the ms3 cam in my ls2 and it could easily be driven every day. My car is a 6 speed, but if the tune is good, and you have big enough stall and gears you will be fine.
Old Nov 7, 2015 | 12:05 AM
Kingc8r's Avatar
I had the MS3 and I sometimes wish I kept it and better optimized it. It was decent with the SS3600 but I think it would;ve done way better with the Circle D 2E that I have sitting in a box.
The MS3 can run hard but it needs to be in a lighter car with a 4000+ stall and the right gearing and supporting mods with a spot on tune.
Like any bigger cam the setup need to be optimized correctly which isn't hard to do.
With the cam choices out now there are better options IMHO
Old Nov 7, 2015 | 01:18 AM
Mazzenger's Avatar
I had an MS3 also. I enjoyed it.
Be sure to get a great tune in it.
And as everyone else says get a high stall (4000+ w/high shift extensions and some gears)
That cam lives in the upper rpms. Mine kept making power up to 7000+ rpm.
