Hydro lock or no?
Old Dec 1, 2015 | 08:05 PM
bbond105's Avatar
I’m with Darth_V8r you’re going to have to get your hands dirty. All anyone can do in internet land is guess. Do a compression test, pull the valve covers, pull the heads, oil pan or take it somewhere and have them check it for you.
Old Dec 2, 2015 | 12:00 PM
nwilson44's Avatar
Well I pulled the valve covers and did not see anything abnormal. I also pulled the # 5 and 6 spark plugs. The number 6 (the cylinder # that had water dropping in it) was really dark and looked like it had oil on it possibly? Maybe just really foul. That's what I have so far.
Attached Thumbnails Hydro lock or no?-valvetrain-1.jpg   Hydro lock or no?-valvetrain-2.jpg   Hydro lock or no?-valvetrain-3.jpg   Hydro lock or no?-valvetrain-4.jpg   Hydro lock or no?-valvetrain-5.jpg
Old Dec 2, 2015 | 01:47 PM
Darth_V8r's Avatar
Moderator
So, that pretty much rules out the top end. i'd say pull the trans next and inspect the clutch area. You'll want to dismantle the clutch and remove the flywheel, since you have thoughts the flywheel could be bent.
If you don't find anything at that point, I would contact a vendor about a long block. There are also plenty of good used engines out there, so I guess it depends on your commitment level to keeping the car long-term. And on the plus side, your almost 3/4 of the way to having the engine removed
Old Dec 2, 2015 | 04:56 PM
tug686spd's Avatar
Number 6 plug looks dark and oily because the piston is not moving. Running the engine like that mixes gas with the water in that cylinder and it disolves the carbon built up on top of piston. While the plug is out hold a finger over plug hole while someone turns over engine to confirm. No sence in trying to find another problem when it all pointing to this. I have 2 motors that suffered the same thing in my garage now.
Old Dec 2, 2015 | 05:59 PM
CBM Motorsports's Avatar
DO A COMPRESSION TEST!!!!
If you find a low cylinder, you know where to start.
