cheap destroked 6.0
cheap destroked 6.0
Ok so I have really being thinking about building a 331 lsx to go with a stock ls1 t56 transmission, for my 91 trans am. I am impressed with the power that they make and how the torque output are with the stress limit of a stock T-56.Are there any members on here who have already built this type on motor already and mange to do it on a ok budget. I have a 4.8 already that's on my engine stand and I was just trying to get actual experienced direction from those that build their motor for a good price.
The 6.0 that I am looking at is just a bare block. I currently have a 4.8 on the engine stand that's in great conditions. The heads has also been ported as well. I have a professional product intake that has also been ported.so I am good as far as the head and intake department is concern. The only thing I would need is the piston ,arp bolts and basic engine prep work from the machine shop down the street from me which is cheap.so it would not be an expensive build. Because just about the rest of the things needed. I have a friend who have a ls7 stock cam down the street from me.that will give the cam to me for under 50 dollars.
what I would need to complete the build would be
now piston rings
6.0 piston
new 4.8 crank bearings
ls2 timing chain cover
arp bolts
gasket set
It will cost me less money to build this motor than to try and find a used 6.0 here in NC they go for 1600 and up. This will be going into my 91 trans am.
now piston rings
6.0 piston
arp bolts
gasket set
I went with 6.3" Lunati rods and Racetec pistons for my 349" combo. They will cut you a piston for any rod you want to use.
Plus, there's nothing budget about custom/aftermarket rods and pistons to make it work especially when 6.0 rotating assemblies are so cheap. If you're worried about destroying your drivetrain there are other ways to reduce torque and power out of a 6.0
I'd rather have a budget 6.0 that's detuned rather than an expensive custom 5.4 LSx if all I was trying to do was keep my tranmission from exploding due to too much torque.
