2001 lq4...any different?
Old Dec 12, 2015 | 02:34 PM
slow93z's Avatar
Default 2001 lq4...any different?
Hey guys, so it looks like the short block lq4 I bought is a 2001. Is there any difference with that early year then any of the other lq4 stuff. Ls t56 still bolt up?
Old Dec 12, 2015 | 03:44 PM
rpturbo's Avatar
Same same. The older ones had the cast iron heads, and the later(2005+) has better rods, but T56 will bolt up no problem.
Old Dec 12, 2015 | 06:46 PM
slow93z's Avatar
Awesome! Thanks! I guess the 99 and 2000 need the fly wheel spacer?
Old Dec 12, 2015 | 08:57 PM
dburt86's Avatar
i thought the engines with cast iron heads have the crank flange thats bigger (spacer built in), which wouldnt work with a t56?
Old Dec 14, 2015 | 11:11 AM
gagliano7's Avatar
The 99-2000 LQ4 have a longer crank so the T56 won't work. The 2001 and up need the spacer for some auto trans but the T56 bolts up.
