Push rod question
Old Dec 16, 2015 | 11:42 PM
Charlie82's Avatar
Default Push rod question
Ok im new to the ls world..... Ive searched and just needing some advise on a correct push rod length.. Ok here we go. Running lq4 with 317 heads. Had heads milled 0.30 with tsp dual valve springs im using a tsp torquer v2 cam 232/234 .600/.600 lift.... Going to install ls7 lifters while heads are off Maybe somebody can help out a newbie here..
Questions are will 7.4 push rods work?can i make up the difference with a thicker head gasket? If so what kind? I already have tsp 7.4 pr and hate to have to purchase another set
Old Dec 17, 2015 | 12:35 AM
Burken01's Avatar
You need to purchase an adjustable pushrod checker for $20 and measure for yourself.
Guessing at pushrod length is not good practice
Old Dec 17, 2015 | 07:11 AM
unit's Avatar
Pushrods need to be the correct length. Too long and you may break something - too short and you will have a valve train noise and lose power. Measure for the correct length and then order them that length. Google "measure pushrods for ls1 engine" and you'll have plenty to read.
Old Dec 17, 2015 | 07:12 AM
vettenuts's Avatar
I would go larger OD as well, 11/32 should work.
Old Dec 17, 2015 | 08:39 AM
Charlie82's Avatar
Thanks for the info I'm going to order a push rod checker... guess it's time to learn something new
Old Dec 17, 2015 | 09:34 AM
gagliano7's Avatar
You will most definitely need shorter pushrods so make sure you measure.
Old Dec 17, 2015 | 09:49 AM
itsslo's Avatar
This!
Old Dec 17, 2015 | 10:02 AM
scotty2000ss's Avatar
Great advice! Get the beefiest one that will fit. Give Al a call at Manton
Old Dec 17, 2015 | 10:18 AM
Charlie82's Avatar
Gonna order a push rod checker. .that 20 bux will save my motor it's well worth it. Don't know how to use it but I've saw a few you tube vids that explain it so I'll give it the old college try
