Dart 225 heads ,any pointers welcome.
Old Dec 21, 2015 | 02:40 PM
vettenuts's Avatar
Maybe AI can provide the flow numbers and you can post them here. I am sure there are others who could use the information as well.
Old Dec 21, 2015 | 02:48 PM
Rise of the Phoenix's Avatar
Here are the AI Dart/RHS 223cc head flow numbers.
Old Jan 19, 2016 | 06:32 PM
AINT SKEERED's Avatar
Anyone can tell me which gasket bore should i go with for stock bore lq4? Ls2 gasket shows a 4.020 bore but i want thinner. I seen trickflow cometic 4.060 bore .045 gaskets. Anyone have experience with these?
The heads were not stock 225s as advertised amd had stock valve job from Dart.
I have them at a machine shop who done my 241s 12 years ago now getting a 5 angle valve Job and touching up short turn radius that someone already cut on.
He is flowing before and after to make sure they are not fubar. (F'ed up beyond all repairs )
Old Jan 20, 2016 | 07:26 AM
vettenuts's Avatar
Don't remember the bore on my gaskets but I am running the 0.040" Cometics. Surface finish and flatness is critical. I also sprayed them with Hylomar spray prior to installation. The bore may be determined by the chamber width and nor the bore, so check both before deciding on the gasket bore size.
Old Jan 20, 2016 | 11:49 AM
windmill's Avatar
this is what I use on my lq4
cometic head gaskets c-5751-.040
Old Jan 20, 2016 | 12:43 PM
Thanks guys
Old Jan 26, 2016 | 04:00 PM
Not to bad. Vj and some touch up on a 4.030 bore
Old Jan 27, 2016 | 07:56 AM
Post up some pictures of the heads if you can. Where all did he touch up at?
Old Jan 27, 2016 | 09:42 AM
He still has them, when i get them back i will.
Short turn and above the valve in the bowl area. Not much
Old Jan 27, 2016 | 10:11 AM
AI flows theirs on a 4.00 bore and your guy did his on a 4.30 bore. Curious if you get higher readings with the larger bore or smaller bore? Just trying to compare the flow numbers. My heads come in at 223cc and yours are 225cc.
Old Jan 27, 2016 | 10:15 AM
4.030 bore will flow more. Dont get caught up in those numbers, these are 225 heads with 2.05 int.valves.
You have higher mid lift numbers ,advanced induction told me he finishes these at 232 cc and i would guess in the 340 cfm range.
These are still as cast with very little touching up done
Old Jan 27, 2016 | 10:54 AM
  #32
True, my heads run stock size valves as well.
Old Jan 27, 2016 | 11:28 AM
  #33
I have an lq4 so the bigger valve can be beneficial to me
Old Jan 27, 2016 | 12:27 PM
  #34
Absolutely. What intake/TB are you going to run?
Old Jan 27, 2016 | 12:42 PM
  #35
I have a ported fast 90 with Nick Williams tb.
With the 6 spd and open cutout with 12 bolt and 4.10 gears my 241s made 452/422
With the automatic swap and a 4500 nitrous converter it put 425/378 through Basani true dual.
11.40 at 118.6 at 3800 rw
Old Feb 11, 2016 | 01:31 PM
  #36
Final product after doing a valve job and back cut on exhaust.
Intake side look where avg flow shows 260
And exhaust look at where it says backcut on valves
60 cc chamber volume with a .045 cometic gasket will be 11/1 compression on my lq4.
I expect to put them on week after next.
With current 241 heads that only flow 257/219 and 10.3/1 compression , the car ran 11.34 @119 with a 1.60 60ft motor @ -.660 da
Ran 10.74 @125 1.50 60 ft on a 75 shot with only 825 bottle psi.
Old Feb 11, 2016 | 02:03 PM
  #37
Any ideas what you expect it to run in NA form with the new heads?
Old Feb 11, 2016 | 04:37 PM
  #38
whatsa347's Avatar
How much did you spend total on the heads after everything?
Old Feb 11, 2016 | 05:18 PM
  #39
64post's Avatar
Can you turn that result sheet upwards?
Old Feb 11, 2016 | 05:28 PM
  #40
64post's Avatar
This is a set of 225's with 2.055" intakes before and after some bowl work. If you get reduce the guide boss, the results are very good. In stock form they suck, sorry.
Attached Thumbnails Dart 225 heads ,any pointers welcome.-013_zpssn6dt2qj.jpg   Dart 225 heads ,any pointers welcome.-009_zpstxw8grlv.jpg   Dart 225 heads ,any pointers welcome.-007_zpsrc0bsvxk.jpg   Dart 225 heads ,any pointers welcome.-006_zps6fhdhtxs.jpg   Dart 225 heads ,any pointers welcome.-009_zpshspvgyvh.jpg
