Some cam input wanted please
Old Dec 17, 2015 | 05:25 PM
MatthewPFinch's Avatar
Default Some cam input wanted please
First off my set up:
1998 Z28 A4 Camaro
Circle D 2600-3200 Converter
3.73 Gears
1 3/4 Longtubes
3'' Duals with X-Pipe and dumps
Stock 243 Heads
Ls6 Intake
Lid
The car is a daily driver so I am curious as to if anyone has experience with the following cam specs. There is a guy selling a new one for a good price, but I can't seem to find a whole lot of info on it.
226/229 .575 .578 112 Lsa
Thoughts on it? Obviously will upgrades springs, retainers, replace oil pump etc. Specifically interested in this cams performance. Looking for improvement under the curve, but I do not want to leave 30hp on the table if there is a better cam for my mild car. Thanks for any insight!
Old Dec 17, 2015 | 05:59 PM
HCI2000SS's Avatar
You'd be leaving power on the table with that cam compared to others
Old Dec 17, 2015 | 06:30 PM
ragtopz28's Avatar
No expert by any means....but I'd go with more intake duration in the 23x range. Contact a sponsor>>>>>>>>>>>>>>> and see what they recommend for you application.
Old Dec 18, 2015 | 07:40 AM
01ssreda4's Avatar
You dont have enough stall to go much bigger. Looking at your stall speed and the fact that its a daily driver id say that's about as big of a cam as youd want to install. Something around 220-224 would really wake the car up and maintain fantastic driveability. Dont listen to the knuckleheads that try to steer you to a cam thats too big for your application.
Old Dec 18, 2015 | 08:23 AM
thunderstruck507's Avatar
I agree with 01ssreda4.
Something like this would be right up your alley IMO: http://store.cammotion.com/the-titan2.
You could probably step up to the Titan 3, but that depends where your stall really falls in that broad RPM range you posted. I erred on the side of caution...driving an overcammed understalled auto is the worst thing ever. I know from experience.
Old Dec 18, 2015 | 08:44 AM
01ssreda4's Avatar
Buddy bought a 222/222 comp cam for dirt cheap. We put that in an m6 car with 4.10 gears and it was a blast to drive, power everywhere, great manners, good gas mileage, it is made for this type of application which is why I recommended what I did. Definitely give cam motion grinds a look.
Old Jan 14, 2016 | 05:36 PM
Converter changed to 3600 lock up with anti balloon plate now. Would this cam be better suited? Can get both new for dirt.... thoughts? Thanks for the input guys! 236/242 .580 .590 112 Lsa
Old Jan 15, 2016 | 07:06 AM
Darth_V8r's Avatar
Moderator
IMO, that's too much cam for a "mild" car. Fusion might say slightly different on the stall, but you might need a 4400 to run that cam halfway decent. If you're in any way concerned about mpg, that cam will kill it.
Old Jan 15, 2016 | 07:52 AM
01ssreda4's Avatar
Yep, I would run a 4k+ converter with that. You can get away with your 3600 no doubt about it, but dont be surprised if you pull up next to me with a smaller cam and get drug
Old Jan 15, 2016 | 08:02 AM
HCI2000SS's Avatar
I run a cam with those exact specs but with more lift. That's with a 6.0 that has 4.10 gears and a 6-speed. Even on my setup I wouldn't want a cam much bigger. Definitely a bit too much for your setup IMO
Old Jan 15, 2016 | 01:21 PM
Thanks for the input think I'll opt for the smaller cam originally I was looking at. Any recommendations on spring kit for this cam?
Old Jan 15, 2016 | 01:40 PM
01ssreda4's Avatar
Prc duals, lunati duals and brian tooley duals are all super popular and proven performers.
Old Jan 15, 2016 | 03:02 PM
Tuskyz28's Avatar
BTR duals get my vote
